fron speakrrs have no treble
arcaudioman
Im running jl speakers all the way around with a jl highs amp and for some reason the front 6.5s have like no treble and significantly lower volume than the 6x9 in the rear any suggestions? I switched rcas at the amp still did It, switched them at hu still did it im lost... also front speakers are nearly new and has done this since day one...
Are they component or coaxial?
Check out your crossovers
You aren't by chance running the signal from the amp to the speakers through any part of the factory wiring, are you? Also what kind of vehicle?
I had this problem when i asked a "audio shop" to instal 4 channel amp and type R components in the front... They used the same wiring which was originally going to my stock 6x9 and connected it with font wiring.. And the 6x9 in the back were way louder than front
sometimes Loud is NOT pretty
Sounds like its safe to go ahead and bend that ass over.
Did you run new speaker wire for them or did you connect them to the rear speaker wire then connect them behind the head unit to the front speaker wire?
yes it matters.. if you put new wires in the back and used stock tiny for the front it makes a difference !
  • Who's Online   0 Members, 0 Anonymous, 1037 Guests (See full list)
