Help... Pioneer TS-W3002D2
Bryan88
I am trying to design a single 12" vented enclosure for my brothers 91 Integra, i tried using the Torres tuning Calculator but cant figure out the Port Dimensions.
i want to get the maximum out of this set up which will be the Pioneer TS-W3002D2 bridged at 1 ohm and i will be using the Pioneer GM-D8601 amp to move this sub...
i measured the maximum size as followed due to keeping some trunk space...
H= 14.5" - 15" Maximum
W= 30" Maximum
D= 11" - 12" Maximum
Here is the spec sheet for the sub
http://www.pioneerelectronics.com/StaticFiles/Manuals/Pioneer%20TS-W3002%202502%20instruction%20manual.pdf
This is as far as i got with the Torres Box Calculator
Try this box calculator if you haven't already. It might help with you port problem. It's RE's. http://reaudio.com/box.php
'01 2DR GMC JimmyPioneer DEH-6300UBMB Quart 6.5'sSoundown Audio SA 8 V2'sMTX RT-202 GONEAudiopipe AP-1800.1D GONE
Bass-less :angry2:
Never mind dont use that
Bass-less :angry2:
So here is a simple suggestion port/subs front for a trunk car:
Enclosure Specifications:
Fb = 34 Hz
Vb = 1.4 ft^3
External Height = 14 in
External Width = 29 in
External Depth = 12 in
Port Width = 1 1/2 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Front & Back (3 parts) = 29 x 14
Left & Right Sides = 9 3/4 x 12 1/2
Top & Bottom = 29 x 9 3/4
L Port Internal Assembly Parts:
Front to Back = 8 1/4 x 12 1/2
Extension = 15 1/4 x 12 1/2
Assembly guide (generic dimensions):
Important notes:
- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.
- All trunk boxes built outside the car need to fit in their way in not just have the right dimensions.
- The port needs 1 1/2" of free airspace in front of it for proper operation.
- Setting your amp subsonic filter to 28Hz is suggested.
Joe, thanks, btw what do you mean by Shared Port Internal Assembly Parts: or should i just ignore that?
also for the port i have the dimensions at the extension for .75 then the actual port is 1.5, is this correct?
Also is there a specific area to mount the sub at or any were in the front is fine?
Ok, fixed that above, sorry, did a sketch for on your dimensions, place the sub as shown.
If you take a look at the sketch, corners inside the port are slanted, do that or round them, if you want to do a 45 inside the port make sure the width of the port stays the same at the corner than elsewhere inside the port, that is 1 1/2".
  • Who's Online   0 Members, 0 Anonymous, 507 Guests (See full list)
