How Much Power Do I Need?
I have 1 18" Q being powered by a Sundown SAE-1000D, 1000 Watt amp. Right now I'm just using the stock battery, and I don't think that it has enough power, because I already killed one battery after only using it very little. I need to know if I should get a better alternator or just a better battery, and maybe a capacitor. I'm not sure what type of battery I should get either... I was looking into getting an Optima yellow top, but I'm not sure which one would fit best in my car. The system is in a 2004.5 model Volvo S40, and I didn't see any Volvo option on Optima's website or any of their dealers.
So, to shorten this up a bit I need to know:
-what battery to get, or if the first battery dieing was just some sort of freak accident that shouldn't happen again
-if i need a better alt.
Here are the amp specs., Wattage is RMS and mine is running right now at 900W-
# 1000 x 1 watts @ 1 ohm
# 600 x 1 watts @ 2 ohms
# 300 x 1 watts @ 4 ohms
# 0.2v - 6v adjustable input sensitivity
# 10 Hz - 350 Hz Frequency Response
# > 90 dB S/N Ratio
# 4-Way Protection Circuit (Thermal, Overload, Speaker Short, and Over Current)
# Linkable to another SAZ-1000D for 1800 watts @ 2 ohms
# 35 Hz - 300 Hz adjustable 24dB Low-Pass Crossover
# 10 Hz - 60 Hz adjustable 24dB Subsonic Filter
# 0 - 180 degree adjustable phase shift
# 0 - 18 dB adjustable bass boost with 45 Hz center frequency
# Wired Remote Control unit included
# 3x 30 Amp Internal Fuses
# 4 AWG power and ground terminals **
# 11.5" L x 10.2" W x 2" H
Edited by Alex
im in the same boat as you right now i have a t1k in a 07 camrymy build
i think the d34 battery fits your because my friend has an s60 and we have the same size battery
im going to be getting a yellow top this week
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
1 optima yellow top (rear)
1 xs power 5100r (front)
big 3 and 1 run 1/0 stinger wire
my build
my rebuild
I just wanted some extra power to be available if I ever wanted to use it. I knew a 1000W amp couldn't really cause much damage to a 2000W sub, and like I said in the first post, I thought my stock system could power it. I have 2 amps in my truck powering 1 12, and 4 door speakers and never had any problem with powering them, but then again I think those 2 amps from my truck have less power combined than the 1 in my car. Anyway, could I just get a yellow top and put it in the trunk and keep the stock battery where it is, would that be too hard on the alt? would a kinetic in back be enough? would a cap. help any? thanks.
Ok, just to clarify here... You really think I need a bigger alternator just to push my amp set at 900w? I was thinking just a good dry cell like a yellow top would do the trick. Not trying to keep asking the same thing over and over, would just like another opinion before I go changing alts.
under powering a sub can hurt the sub
False on so many levels. Under powering a sub generally leads to people throwing a dirty signal at it to get it louder. Clipping/distortion comes in, then game over, but I doubt 1000 watts is even moving a BTL.
  • Who's Online   0 Members, 0 Anonymous, 1817 Guests (See full list)
