mowfish23 Posted March 30, 2013 Report Share Posted March 30, 2013 Ok i need help building first ported box the subs are hifonics brutus 15s and the minimum box spec is 2.0 feet to the maximum which is 4.0 so can anyone give me boxs specs Link to comment Share on other sites More sharing options...
OG BudBone Posted March 30, 2013 Report Share Posted March 30, 2013 Ok i need help building first ported box the subs are hifonics brutus 15s and the minimum box spec is 2.0 feet to the maximum which is 4.0 so can anyone give me boxs specs Post max vehicle dimensions and models of equipment and I'm sure someone will chime in. Need details brotha 1997 Trans Am WS6 Pioneer DEH-P5200HD 2 DC Level 4 M2 12s 4 cubes tuned to about 34hz DC 3.5k 1/0 Welding Supply Ultra Flex Stock 140A alt Stinger Fuses & Fuse Holders XS Power D5100 XS Power XP3000 Link to comment Share on other sites More sharing options...
OG BudBone Posted March 30, 2013 Report Share Posted March 30, 2013 Also this should probably be in the enclosures section 1997 Trans Am WS6 Pioneer DEH-P5200HD 2 DC Level 4 M2 12s 4 cubes tuned to about 34hz DC 3.5k 1/0 Welding Supply Ultra Flex Stock 140A alt Stinger Fuses & Fuse Holders XS Power D5100 XS Power XP3000 Link to comment Share on other sites More sharing options...
mowfish23 Posted March 31, 2013 Author Report Share Posted March 31, 2013 The build is open to trunk or back seat trunk specs 35l 13h 20w back seat 41L 20w 20h Link to comment Share on other sites More sharing options...
mowfish23 Posted March 31, 2013 Author Report Share Posted March 31, 2013 My bad trunk is 35 16 20 Link to comment Share on other sites More sharing options...
Sonic Posted March 31, 2013 Report Share Posted March 31, 2013 You have 5.2 cuft internal with those dimension, hence you can comfortably do a single 15". Link to comment Share on other sites More sharing options...
mowfish23 Posted March 31, 2013 Author Report Share Posted March 31, 2013 Well i bought 2 so I'm not at all sure how to make them fight Link to comment Share on other sites More sharing options...
Joe X Posted March 31, 2013 Report Share Posted March 31, 2013 OP you should state the exact model for the subs and amp, likely you will need a little more than 16h to fit them properly. Link to comment Share on other sites More sharing options...
mowfish23 Posted March 31, 2013 Author Report Share Posted March 31, 2013 I'm not sure on the amp since I'm buying a new one in two weeks but the subs are hifonics brutus 15 brz15d4 Link to comment Share on other sites More sharing options...
Joe X Posted March 31, 2013 Report Share Posted March 31, 2013 Well yes their tightest spec is 2 cubes per sub, I'm sure it will lack low end and sound tight but if you still want it, here it goes: ** pay attention to the notes below the pic, may save you from considerable trouble. Enclosure Specifications:Fb = 35.2 HzVb = 4 ft^3External Height = 16.5 inExternal Width = 35 inExternal Depth = 20 inPort Width = 3 3/4 inCut Sheet List:* All Dimensions in Inches.* Wood Thickness is 3/4 for all Parts.External Enclosure Parts:2 x Top & Bottom (3 parts) = 35 x 20Left & Right Sides =Side 1 = 18 1/2 x 14 1/4Side 2 = 19 1/4 x 14 1/4Front = 30 1/2 x 14 1/4Back = 35 x 14 1/4L Port Internal Assembly Parts:Front to Back = 14 3/4 x 14 1/4Extension = 1 1/4 x 14 1/4 Assembly guide (generic dimensions): Important notes:- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.- All trunk boxes built outside the car need to fit in their way in not just have the right dimensions.- The port needs 3 3/4" of free airspace in front of it for proper operation.- Setting your amp subsonic filter to 28Hz is suggested. Link to comment Share on other sites More sharing options...
