XxshadowdawgxX Posted April 1, 2013 Report Share Posted April 1, 2013 I had a trailblazer I had my Fi SP4 18'' in beforehand. Now that it is gone I'm hoping to put my SP4 into my cruze. I have the dimensions and am hoping someone has a box building design software and can help me out. My dimensions maxes are ..... Width - 38'' Height - 20'' preferably 19'' Depth - 24", hoping for a little smaller. My goal is a box tuned from 28-32hz that has a general size of over 6 cubic feet. Long as its over 6 cubic feet after displacements I am a happy camper. The port I'll leave up to you professionals out there that are hopefully going to help me out here. Thanks everyone. I appreciate all help. Link to comment Share on other sites More sharing options...
Joe X Posted April 2, 2013 Report Share Posted April 2, 2013 Outstanding that you can do 20" h in a trunk car, here is a suggestion: Enclosure Specifications:Fb = 32.2 HzVb = 6 ft^3External Height = 20 inExternal Width = 38 inExternal Depth = 24 inPort Width = 5 3/4 inCut Sheet List:* All Dimensions in Inches.* Wood Thickness is 3/4 for all Parts.External Enclosure Parts:2 x Front & Back (3 parts) = 38 x 20Left & Right Sides = 21 3/4 x 18 1/2Top & Bottom = 38 x 21 3/4L Port Internal Assembly Parts:Front to Back = 16 x 18 1/2Extension = 11 x 18 1/2 Assembly guide (generic dimensions): Important notes:- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.- All trunk boxes built outside the car need to fit in their way in not just have the right dimensions.- The port needs 5 3/4" of free airspace in front of it for proper operation.- Setting your amp subsonic filter to 28Hz is suggested. Link to comment Share on other sites More sharing options...
XxshadowdawgxX Posted April 4, 2013 Author Report Share Posted April 4, 2013 Yeah the Chevrolet Cruze has a absolutely massive trunk. I may very well have to rearrange the numbers as more information comes across as I begin to start building. These were the base measurements I was able to come up with though. Outstanding that you can do 20" h in a trunk car, here is a suggestion: Enclosure Specifications:Fb = 32.2 HzVb = 6 ft^3External Height = 20 inExternal Width = 38 inExternal Depth = 24 inPort Width = 5 3/4 inCut Sheet List:* All Dimensions in Inches.* Wood Thickness is 3/4 for all Parts.External Enclosure Parts:2 x Front & Back (3 parts) = 38 x 20Left & Right Sides = 21 3/4 x 18 1/2Top & Bottom = 38 x 21 3/4L Port Internal Assembly Parts:Front to Back = 16 x 18 1/2Extension = 11 x 18 1/2 Assembly guide (generic dimensions): Important notes:- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.- All trunk boxes built outside the car need to fit in their way in not just have the right dimensions.- The port needs 5 3/4" of free airspace in front of it for proper operation.- Setting your amp subsonic filter to 28Hz is suggested. Link to comment Share on other sites More sharing options...
Joe X Posted April 4, 2013 Report Share Posted April 4, 2013 When you have more accurate dimensions let me know and I will tweak it a bit so that it fits. Link to comment Share on other sites More sharing options...
