CarAudioFab Posted April 2, 2013 Report Share Posted April 2, 2013 In this episode of "Car Audio Fabrication" I share the proper way to utilize T-Nuts in an install. The advantages of T Nuts are as follows: Screws can be removed several times if you need to access the inside of the enclosure with no worry of srtipping or degrading the thread quality (like what would occur with wood screws into wood) More secure mounting, they cannot be pulled loose from the mounting surface as occurs with wood screws. Other notes: Adding a dab of super glue before securing the t nut to the wood can prevent them from falling into the enclosure before installing. Using a size down from the shank of the t nut for your drill hole allows for a tighter squeeze on the nut. Hurricane nuts are also available which "turn" into the mounting surface rather than bite. I hope you guys enjoy! Discuss below and if you enjoy the content Subscribe! ~Mark -Mark Host of "CarAudioFabrication" - YouTube Car Audio Tutorial Channel Check out my forum section here on SMD for my builds and tutorial videos! Subscribe on YouTube: http://www.youtube.com/CarAudioFabrication Link to comment Share on other sites More sharing options...
81000D Posted April 2, 2013 Report Share Posted April 2, 2013 What do you mean with the hurricane nuts. Which would work better for mdf.? I have been thinking about using these for my next box. Link to comment Share on other sites More sharing options...
n1ghtsn1p3r Posted April 2, 2013 Report Share Posted April 2, 2013 The only thing I hate about T-nuts is when the little spikes break off or start to pull out and get bent. Then they don't bite the wood anymore and start spinning. I've seen it happen with furniture, especially if the threads get trashed. I sometimes beat mine in with a mallet, or I do the method in the video. Just depends on if the screw/bolt length and also whatever other tools I have around. 2016 Ford Focus SE No build log yetDC Audio 1.2K2x DC Audio Level 2 10" Link to comment Share on other sites More sharing options...
CarAudioFab Posted April 3, 2013 Author Report Share Posted April 3, 2013 The only thing I hate about T-nuts is when the little spikes break off or start to pull out and get bent. Then they don't bite the wood anymore and start spinning. I've seen it happen with furniture, especially if the threads get trashed. I sometimes beat mine in with a mallet, or I do the method in the video. Just depends on if the screw/bolt length and also whatever other tools I have around. I would imagine with a harder wood (hahah harder wood) they may have more issues with the spikes, but I have yet to see them break off when utilized with MDF. -Mark Host of "CarAudioFabrication" - YouTube Car Audio Tutorial Channel Check out my forum section here on SMD for my builds and tutorial videos! Subscribe on YouTube: http://www.youtube.com/CarAudioFabrication Link to comment Share on other sites More sharing options...
81000D Posted April 3, 2013 Report Share Posted April 3, 2013 Whats the difference between t nuts and hurrican nuts. Need to know before I order. Will be for double baffle mdf. Link to comment Share on other sites More sharing options...
larrys95civic Posted April 3, 2013 Report Share Posted April 3, 2013 google is a wonderful tool http://www.parts-express.com/pe/showdetl.cfm?partnumber=081-1084&utm_source=google&utm_medium=cpc&utm_campaign=pla Team Superior SPL Former Installer at Driven Sound & Security http://www.drivenss.com All kinds of forsale threads http://www.stevemeadedesigns.com/board/topic/164247-amps-subs-and-misc/#entry2383262 http://www.stevemeadedesigns.com/board/topic/164430-polk-audio-sda6000-sound-bar/#entry2386634 http://www.stevemeadedesigns.com/board/topic/164279-3-michael-kors-watches/#entry2383983 http://www.stevemeadedesigns.com/board/topic/164549-more-items-from-storage/ http://www.stevemeadedesigns.com/board/topic/166967-dd-9518s-amps-kenwood-custom-explorer-dash/ If someone is feeling generous I'd love an original sig LOL Link to comment Share on other sites More sharing options...
