Need help to see if I have enough room for 2 sa 15s or 3 sa 12s
I drive a Ford Focus 2012 Sedan and I am trying to see if I can fit 3 12s or 2 15s (both sundown sa) in my trunk. I have about 2200 watts rms that i will put to them and I want to be able to tune it low for music not SPL. I have a z v3 15 in a 3ft^3 tuned to 33hz right now with the 2200 watts but want more cone area. The biggest enslosure I can fit would be 13.5" Height, 30" Wide and 28" Deep. Thanks for the help.
Without taking sub displacement, port volume or any bracing into account, those dimensions give you around 5.25 cubes. Sundown recommends 3 SA 12's have 1.5 - 2.0 cubes per, and 2 SA 15's 3.0 - 4.0 cubes per. So you would need 4.5- 6.0 cubes for 3-12's or 6.0 - 8.0 cubes for 2-15's.
You can barely fit 2 12's, best I got from your dimensions is 3.8 cu ft, 32hz with 12.6 per cube after all displacements after doing a quick torres calculation
Another problem with your dimensions, you don't have enough height for 15's, so you would have to have subs firing up as well.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
  • Who's Online   1 Member, 0 Anonymous, 628 Guests (See full list)
