I have a question because I have no idea. Ok so i installed my audio system i just got done building in my blazer suv and all the sudden my clarm was arming wired and my dome light wasnt comming on and my tailgate would pop but i blew a fuse what would of caused that
Mr ChevyBlazerMan
Setup
ALarm :) Prestige 2 way screen + Shock senser/Proximty Senser
Memphis Eq
2 Kicker Cvx 15 2 ohm
Custom Ported Box Made By Me :)
Amp Is Hifonics Brutus 1700D
Dash Speakers Not Sure on Model But They Are 3.5 Memphis
Door Speakers 2 Orion Xtr Pro Tweeters
Door Speakers 4 Orion Xtr Pro 6.5s
0 Gauge wire around in truck
Xs Power 3400d just got one from local shop on a discount. Just installed today with the big 3 upgrade O guage
Tomorrow hoping to run all door speaker and hook up my 4 channel Rockford amp
Nope im running 2 Kicker Cvxs 15s in custom box with a hifonice brutus 1700.. but nope i did not screw into any medal
Mr ChevyBlazerMan
Setup
Memphis Eq
Was the system playing fine at all or first time you tried to play it that happened?
If it was playing and randomly happened it could be unrelated. If not the. Try disconnecting the amp from battery ( leave everything but just disconnect and tape it off and see if that changes anything?
well everything works now i was just wondering why would i blow a fuse my buddy suggested it could be from a the power my amp is taking but idk
Mr ChevyBlazerMan
Setup
Memphis Eq
What year is the blazer?
What head unit are you using?
Where did you run your amplifier wires?
What size wire is it?
Where did you ground your amplifier?
Can you post pictures of the installation?
my wires all 4 guage but i do have 0 guage i plan on running once i get my kintek battery in i just ordered one.
1996 Blazer
I ran Power wire on passenger side and remote wire and Rcas on driver side
power wire and ground are 4 guage till later next week im running 0 guage just waiting on my battery
and ground was ran between the back seats but the ground was ran on and bolt new bolt not on the seat frame bolts i drilled and taped and new bolt under the seat
how do i post pics of my setup
Mr ChevyBlazerMan
Setup
Memphis Eq
did you sand the area down before bolting to post pics i upload on photobucket then just select the image and on the right the image file then just paste it in here
yes i did i grinded it all down and took all paint of and all
Mr ChevyBlazerMan
Setup
Memphis Eq
  • Who's Online   0 Members, 0 Anonymous, 502 Guests (See full list)
