HunterJohnson Posted April 13, 2013 Report Posted April 13, 2013 DAmoreEngineering 1 month ago If the head unit has SE outputs and the amplifier has SE inputs = coax cable If the head unit has SE outputs and the amplifier has Diff inputs = twisted pair If the head unit has Diff outputs and the amplifier has Diff inputs = twister pair If the head unit has Diff outputs and the amplifier has SE inputs = bad no matter what as you will shorting out half of the head unit's outputs. In this case you would need an amplifier with Diff inputs or a converter to convert the head unit's outputs to SE Edit: also was wrong about the pioneer deh 80prs it is coax not twisted. just went to car and double checked Are you sure I tested and didn't get any resistance Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
LordArcane Posted April 13, 2013 Report Posted April 13, 2013 DAmoreEngineering 1 month ago If the head unit has SE outputs and the amplifier has SE inputs = coax cable If the head unit has SE outputs and the amplifier has Diff inputs = twisted pair If the head unit has Diff outputs and the amplifier has Diff inputs = twister pair If the head unit has Diff outputs and the amplifier has SE inputs = bad no matter what as you will shorting out half of the head unit's outputs. In this case you would need an amplifier with Diff inputs or a converter to convert the head unit's outputs to SE Edit: also was wrong about the pioneer deh 80prs it is coax not twisted. just went to car and double checked Are you sure I tested and didn't get any resistance Double Checked again, also made video. pretty easy, - lead in main ground, check to make sure head unit shares this ground (if it doesn't you might have ground issues), then check outer ring of RCA outputs on head unit. http://www.youtube.com/watch?v=VKVJGxO1bso does this with RCA's hooked up or not, do not need it powered on as it deals with the grounding side of things.
HunterJohnson Posted April 13, 2013 Report Posted April 13, 2013 DAmoreEngineering 1 month ago If the head unit has SE outputs and the amplifier has SE inputs = coax cable If the head unit has SE outputs and the amplifier has Diff inputs = twisted pair If the head unit has Diff outputs and the amplifier has Diff inputs = twister pair If the head unit has Diff outputs and the amplifier has SE inputs = bad no matter what as you will shorting out half of the head unit's outputs. In this case you would need an amplifier with Diff inputs or a converter to convert the head unit's outputs to SE Edit: also was wrong about the pioneer deh 80prs it is coax not twisted. just went to car and double checked Are you sure I tested and didn't get any resistanceDouble Checked again, also made video. pretty easy, - lead in main ground, check to make sure head unit shares this ground (if it doesn't you might have ground issues), then check outer ring of RCA outputs on head unit. http://www.youtube.com/watch?v=VKVJGxO1bso does this with RCA's hooked up or not, do not need it powered on as it deals with the grounding side of things. Thanks for explaining, I was doing it wrong. So how would u check for amps? Ground of batt to ground of RCA? Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
LordArcane Posted April 13, 2013 Report Posted April 13, 2013 i just got done making 2 videos going into detail on how to test amps, and head units. i will be posting them up shortly
HunterJohnson Posted April 13, 2013 Report Posted April 13, 2013 Thank you sir Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
LordArcane Posted April 13, 2013 Report Posted April 13, 2013 not a problem, took me a min to get it but really it is so simple i think thats why so many are getting confused. like me they were probably overthinking it
HunterJohnson Posted April 13, 2013 Report Posted April 13, 2013 I'm Forsure over thinking it Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
