Cboeger Posted April 9, 2013 Report Share Posted April 9, 2013 I have subs that can go to 18hz, but its bad for them most likely, the lower the hz the lower bass notes you can hit correct? In order for your subs to be tuned to a lower hz you need more box space, correct? Link to comment Share on other sites More sharing options...
revoracing247 Posted April 9, 2013 Report Share Posted April 9, 2013 uhhh it's way more complicated then that but first, why do you say your sub can go to 18hz? is that it's frequency response? is that it's fs? and no it's not just the lower the notes you want to hit the bigger the box needs to be. the box size effects a lot of things just like the port length and area also play a big role into how the box plays. I think you have a bit of truck stuck in your mud bro ~Ford Ranger, ext cabKenwood DDX4701/0ga stinger wiring for big 31/0ga ofc flextech wiring 3 kinetik 800's AQ2200 @1ohm Sundown Audio X15 in a 27Hz tuned ported box LE BUILD LOG!!! Link to comment Share on other sites More sharing options...
Joe X Posted April 9, 2013 Report Share Posted April 9, 2013 I have subs that can go to 18hz, but its bad for them most likely, the lower the hz the lower bass notes you can hit correct? In order for your subs to be tuned to a lower hz you need more box space, correct? You can't hear 18Hz (most humans can't anyways), what you can hear is the sub bottoming out. State your vehicle and equipment infos, box max dims, to see what can be done. Link to comment Share on other sites More sharing options...
