Mobileaudio25 Posted April 9, 2013 Report Posted April 9, 2013 I have an old school 200 w 4 channel boss havoc amplifier. It has an option for low/flat/high settings but it also has a low pass knob. If I put the amp on the high setting will I still need to mess with the low pass knob?
8ight Posted April 9, 2013 Report Posted April 9, 2013 I am guessing those settings mean low pass, crossover disable (flat, must be off?), and high pass. How many pots (knobs) do you have access to? If it is just that one then it should set the crossover frequency. I'm gonna hate
Mobileaudio25 Posted April 9, 2013 Author Report Posted April 9, 2013 I'll snap a picture of the amp when I get home in about 2 hrs, and you can let me know what you think....
Mobileaudio25 Posted April 11, 2013 Author Report Posted April 11, 2013 Here a picture of the amp settings, thanks for the help
Socky Posted April 11, 2013 Report Posted April 11, 2013 the high setting with disable the low pass now, full is all freq going to it. Lowpass is just the lower end and up till you set the filter Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell Kenwood H/U 1/0 wire, 136 amp alt 200 ah batteries 12.7 daily 2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts Mb quart 125.4 wired to 4 aura 6's 3.6 cube box tuned to 36 plays down to 23hz
Mobileaudio25 Posted April 11, 2013 Author Report Posted April 11, 2013 Ok, , I don't like much bass coming for my vocal speakers. So if I put it on high pass and then adjust the general eq to 1.25 kHz I think is what it is I'll be safe right?
8ight Posted April 12, 2013 Report Posted April 12, 2013 Ok, , I don't like much bass coming for my vocal speakers. So if I put it on high pass and then adjust the general eq to 1.25 kHz I think is what it is I'll be safe right? Please take a picture of the entire EQ section showing all of the switches/knobs you have. I still cannot determine the full functionality of this crossover from what I can find online. Usually anything labeled an EQ is just that, an equalizer, not a filter like a crossover. I am thinking that the low-pass knob is what you use to set the crossover point but I am not sure what else you have control of. I'm gonna hate
Mobileaudio25 Posted April 12, 2013 Author Report Posted April 12, 2013 Those are all of the settings and knobs that are on the amplifier. The others I were referring to were on the head unit .
8ight Posted April 14, 2013 Report Posted April 14, 2013 Then use the low pass knob to set the crossover frequency, flat ought to turn it off. I'm gonna hate
