12volt_Trini Posted April 11, 2013 Report Share Posted April 11, 2013 Hey, I just wanted to know if anyone has any experience with this woofer and what size of enclosure would be ideal for it?....A tuning frequency would be highly appreciated too! Vehicle: 2000 Toyota Corolla Limited S Head Unit: DEX 99rs pioneer Speakers Sub treble/High mid : 2 1.4 inch throat 2080 18 sound drivers neodyium with wave guide Tweeters: 2 Mtx dome, 4 APT eminence super tweeters Mid Range: 2 18Sound 6" 6ND410 NEO,2 18 Sound 10" 10NDA610 NEO Low Mid Range: 2 18 Sound 10 NMB420 Sub: 2 Z-12 V.3 D1 - Sundown Audio Amplifiers Sub treble/High Mid: MTX Audio TA5302 Thunder Tweeters: JL Audio e4300 4-Channel Mid range: MTX Audio TC3002 Mid range: MTX Audio TA7402 Thunder 7402 Low Mid Range: MTX Audio TA7402 Thunder 7402 Sub: MTX Thunder Elite 4001D Alternator: 220amp mechman Batteries: 3 D3100 XS Power Link to comment Share on other sites More sharing options...
Ben Fultz Posted April 11, 2013 Report Share Posted April 11, 2013 http://www.powerbassusa.com/s-104x-s-104dx-10-subwoofer Click owners manual. Link to comment Share on other sites More sharing options...
Joe X Posted April 12, 2013 Report Share Posted April 12, 2013 Here is a suggestion: Enclosure Specifications:Fb = 35 HzVb = 1.3 ft^3External Height = 14 inExternal Width = 23 inExternal Depth = 13 inPort Width = 1 1/2 inCut Sheet List:* All Dimensions in Inches.* Wood Thickness is 3/4 for all Parts.External Enclosure Parts:Front = 20 3/4 x 12 1/2Back = 23 x 12 1/2Left & Right Sides:Side 1 = 11 1/2 x 12 1/2Side 2 = 12 1/4 x 12 1/2Top & Bottom = 23 x 13L Port Internal Assembly Parts:Front to Back = 10 x 12 1/2Extension = 14 1/2 x 12 1/2 Assembly guide (generic dimensions): Important notes:- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.- All trunk boxes built outside the car need to fit in their way in not just have the right dimensions.- The port needs 1 1/2" of free airspace in front of it for proper operation.- Setting your amp subsonic filter to 28Hz is suggested. BTW, cool head unit! Link to comment Share on other sites More sharing options...
12volt_Trini Posted April 12, 2013 Author Report Share Posted April 12, 2013 Thanks i think that dimensions was exactly what i was looking for....it is to go in a mazda 3...5 channel precision power to play the doors and single bass should be a decent small set up....lol yea the head unit is excellent u can incorporate a large system and with alot of patience it can be very very clean Vehicle: 2000 Toyota Corolla Limited S Head Unit: DEX 99rs pioneer Speakers Sub treble/High mid : 2 1.4 inch throat 2080 18 sound drivers neodyium with wave guide Tweeters: 2 Mtx dome, 4 APT eminence super tweeters Mid Range: 2 18Sound 6" 6ND410 NEO,2 18 Sound 10" 10NDA610 NEO Low Mid Range: 2 18 Sound 10 NMB420 Sub: 2 Z-12 V.3 D1 - Sundown Audio Amplifiers Sub treble/High Mid: MTX Audio TA5302 Thunder Tweeters: JL Audio e4300 4-Channel Mid range: MTX Audio TC3002 Mid range: MTX Audio TA7402 Thunder 7402 Low Mid Range: MTX Audio TA7402 Thunder 7402 Sub: MTX Thunder Elite 4001D Alternator: 220amp mechman Batteries: 3 D3100 XS Power Link to comment Share on other sites More sharing options...
Joe X Posted April 12, 2013 Report Share Posted April 12, 2013 Ok man, if the dims need to be tweaked a bit just let me know. Link to comment Share on other sites More sharing options...
12volt_Trini Posted April 12, 2013 Author Report Share Posted April 12, 2013 if i do the 45s what difference would it make? Vehicle: 2000 Toyota Corolla Limited S Head Unit: DEX 99rs pioneer Speakers Sub treble/High mid : 2 1.4 inch throat 2080 18 sound drivers neodyium with wave guide Tweeters: 2 Mtx dome, 4 APT eminence super tweeters Mid Range: 2 18Sound 6" 6ND410 NEO,2 18 Sound 10" 10NDA610 NEO Low Mid Range: 2 18 Sound 10 NMB420 Sub: 2 Z-12 V.3 D1 - Sundown Audio Amplifiers Sub treble/High Mid: MTX Audio TA5302 Thunder Tweeters: JL Audio e4300 4-Channel Mid range: MTX Audio TC3002 Mid range: MTX Audio TA7402 Thunder 7402 Low Mid Range: MTX Audio TA7402 Thunder 7402 Sub: MTX Thunder Elite 4001D Alternator: 220amp mechman Batteries: 3 D3100 XS Power Link to comment Share on other sites More sharing options...
Joe X Posted April 12, 2013 Report Share Posted April 12, 2013 If you find hard to do the 45s just slant or round any sharp edges inside the port at the turn and on the ends and that will be enough. Also don't push much more than rated power to the sub on this box, regardless do use the subsonic filter and set your gains properly. Link to comment Share on other sites More sharing options...
12volt_Trini Posted April 13, 2013 Author Report Share Posted April 13, 2013 I think ill stick the dimensions you sent me....try it out first and maybe later i could try building using the 45s....im new to the building thing...so its a learning process. thanks very much for your help tho! Vehicle: 2000 Toyota Corolla Limited S Head Unit: DEX 99rs pioneer Speakers Sub treble/High mid : 2 1.4 inch throat 2080 18 sound drivers neodyium with wave guide Tweeters: 2 Mtx dome, 4 APT eminence super tweeters Mid Range: 2 18Sound 6" 6ND410 NEO,2 18 Sound 10" 10NDA610 NEO Low Mid Range: 2 18 Sound 10 NMB420 Sub: 2 Z-12 V.3 D1 - Sundown Audio Amplifiers Sub treble/High Mid: MTX Audio TA5302 Thunder Tweeters: JL Audio e4300 4-Channel Mid range: MTX Audio TC3002 Mid range: MTX Audio TA7402 Thunder 7402 Low Mid Range: MTX Audio TA7402 Thunder 7402 Sub: MTX Thunder Elite 4001D Alternator: 220amp mechman Batteries: 3 D3100 XS Power Link to comment Share on other sites More sharing options...
