soundstream15 Posted April 16, 2013 Report Posted April 16, 2013 I installed a AQ2200 last week to replace my AQ1200d I hooked it up an everything. I'm running 1/0awg from front battery to rear battery along with ground, big 4 in 1/0g kitneik hc1200 and I have 4awg from rear battery to amp. I haven't really played full tilt bc the 4awg but I did so tonight. I played daddy's home. The first 3 notes it stayed in the mid to high 13s then once it hit 27hz I dropped to 12.4volts. When I had my 1200 I only dipped to 13.6 on that Song. Is it bc the power? The 4awg? I am installing 1/0awg from battery to amp tomorrow. I also have stock alt. i wanna say I have have low rise at lower notes?
soundstream15 Posted April 16, 2013 Author Report Posted April 16, 2013 also when i run the 1/0g from rear battery to amp. do i need to fuse it?
TRTC360 Posted April 16, 2013 Report Posted April 16, 2013 you're running a 2200 watt amp with only a HC1200 as a secondary batt, that's the problem, gotta beef up that electrical man! iirc you have the most rise at and around tuning, atleast that's what i've seen in a lot of setups. '93 Firebird Formula V8 H/U- Kenwood eXcelon KDC-X395 Mids/Highs Amp- Hifonics ZXI80.4 Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0 G34 Red Top and a 180amp Ford Alternator www.youtube.com/TRTC360
ric006 Posted April 16, 2013 Report Posted April 16, 2013 and i dont know how many amps your alt puts out so u need a bigger battery in back like an HC2000B
soundstream15 Posted April 16, 2013 Author Report Posted April 16, 2013 yeah lol gotta upgrade that. i will fuse that then, i just was not sure if it was nessasary when its only a ft or so away. i thought about hc2400 or xs power
soundstream15 Posted April 16, 2013 Author Report Posted April 16, 2013 Anyone ever hear krank it up batteries?
Guest Posted April 16, 2013 Report Posted April 16, 2013 more power obviously will cause more voltage drop.
Crandis16 Posted April 16, 2013 Report Posted April 16, 2013 Never heard of Krank it up batteries Is under hood battery upgraded too? My Red zx2 Build Log My Black zx2 Build Log My Red zx2 UBL
soundstream15 Posted April 16, 2013 Author Report Posted April 16, 2013 Yellow optima under hood. Anyone selling a battery:)
