Help needed with Custom Enclosure for 2 Sundown Audio SA 12's
Funtoss
Hi guys, i recently purchased 2 SA 12's and was wondering if my box design is good enough for the two subs?
specs:
SUNDOWN AUDIO SA 12 -D4 gonna be running at 1 ohm 2000w rms on a SHOK II amp
vehicle is a mitsubishi lancer 1996, 4 door sedan trunk.
dimensions that the car has :
35 width
17 height
26 depth
here is my box that i am planning to make
http://i.imgur.com/YEoUeIG.png
is my enclosure good enough for 2 12's??
I also play a lot of rap music range from 30hz - 45hz
if you guys have your designs or help me design one for me then I would appreciate it very much and would be very greatful to you
really need some help here , thank you
Enclosure Specifications:
Fb = 34.5 Hz
Vb = 3.8 ft^3
External Height = 14.5 in
External Width = 35 in
External Depth = 22 in
Port Width = 4 1/4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2x Front = 15 3/8 x 13
2x Front Internal = 13 7/8 x 13
Back = 35 x 13
Left & Right Sides: 20 1/2 x 13
Top & Bottom = 35 x 22
Shared Port Internal Assembly Parts:
2 x Front to Back = 18 3/8 x 13
2 x Extension = 1 11/16 x 13
Assembly guide (generic dimensions):
Important notes:
- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.
- All trunk boxes built outside the car need to fit in their way in not just have the right dimensions.
- The port needs 4 1/4" of free airspace in front of it for proper operation.
- Setting your amp subsonic filter to 28Hz is suggested.
is there anything wrong with my design on reaudio? is the port okay?
I didn't check it and that's because the Re calculator itself has issues and don't account for the displacement of the drivers, if you take a look at the box I left, you can know the port area I gave and just about anything else about it. I can tell you that it will work as posted but if you decide on different parameters you can use mine just as a reference.
  • 6 months later...
hey joe x....could you help me with my port size man? i have most of my cut out just need my port size so i can tune to 32hz, also have 2 sa 12....need the port size and the bracing size ...i have a box dimensions of w36 x d22 xh14, can go 38wide....also have another box dimensiton with the sise of w32 x d22 x h14 with the port of 3 inch wide and 18.2 length but i think its wrong
Ok, say you do a w36 x d22 x h14 box. then to be tuned to 32 Hz you need the following:
Port width would be 4"
2 x Front to Back = 18 1/2 x 12 1/2
2 x Extension = 2 3/4 x 12 1/2
Following this assembly style in the pic below the two front pieces would need to be:
2x Front = 16 x 12 1/2
Made like stated above your box spec would be 3.9 cubic feet @32 Hz 50 square inches of port area, if you have any questions let me know.
Sundown recommends 3.5 ft^ net size..with 50" squared port area and tune to 35htz for optimal performance..about 1500 watts of power to em and its all good..now I think anythimg bigger than that you would need to use less power to keep the suspension under control
You need trunk space to get groceries and shit...bitches love groceries
well I planned in using 1000rms for now the move up to 1500 rms since i already have a new jl audio jx 1000/1D i havent used
I like joe x box and think its pretty accurated tho,....i wokerd with this other guy no make a box and came up witha box with measurements of Depth 22' height 14.5' width 36' (all outside dimensions) with a a port of 13' height 4' wide and 27' long....how does that sound????
  • 9 months later...
If someone would help me design a box for 3 sa 12s.. It's going in an extended cab colorado so Ima face them up in my back seat. I have like 44inches of space wide it can stand 22inches high and it can be 14inches deep.. I want it tuned to 36hrz can someone help it be much appreciated trying to do a nice ported box for maximum DBS
  • Who's Online   0 Members, 0 Anonymous, 1864 Guests (See full list)
