wiring in a batt. few questions
i plan on having a 1000-1200rms setup i have a 2010 chrysler 300 with stock alt/batt
i want to do the big3 and maybe add a small batt if needed (part of my question) and maybe point me in the direction of a wiring diagram?
starting fresh, chrysler 300.. no subs amp nothin
I NEED HELP looking to purchase saz-1500d and 15" 1000rms subREFS- feedback/refs.. click!
big3 - upgrade battery groundings(two wires) and power wire from alt..
for groundings u r looking for most solid piece of metal (chassis) u can locate under the hood..
sometimes Loud is NOT pretty
Sounds like its safe to go ahead and bend that ass over.
No need for a wiring diagram.
Big 3 is as follows:
-alternator positive to battery positive. Self explanatory where to hook it up.
-Engine ground to chassis ground. Personally, I like to put the engine ground on the bolt that holds the alternator in. Since you are ultimately trying to ground the alternator and what better way to do it than to put the wire as close to the alt as possible? For the body ground: sanding off the paint around a strut tower bolt is usually your best bet. Just make sure to put some silicone/dielectric grease on the part you sanded to seal out moisture.
-Battery negative to chassis ground. Like above: attach the terminal to the strut tower.
Oh... And add on to factory wires. Don't replace them
  • Who's Online   1 Member, 0 Anonymous, 1217 Guests (See full list)
