FluttershyTBB Posted April 23, 2013 Report Posted April 23, 2013 Hi, I am looking to get a bigger system, but I don't know what equipment to get. I have a '96 Mercedes-Benz s600 (w140) with 2 12" Sony X-plod subs, 1 nitro(unsure of model number) amp, and a Kenwood KDC-152 head unit. I do not know much about car audio, however I am learning. Any advice would be great Thanks!, ~Fluttershy
john253a Posted April 23, 2013 Report Posted April 23, 2013 Best bet is to post some measurements of you truck Measure it at if it was a square box Post them here and then say out of what u have listed above, you would like to use? Then list you elec system weather it be stock or what not From that we can do some mock boxes on Torres calculator and see what's what From that you'll then no what is and what's not possible And make you chooses based on that What I like to do Once I no how much space is available I look at the elect system and see what it can support Most stock systems can handle 1000-1500 no problem and with some extra batteries a bit more Now that I no how much power and space I have I start looking at options based on a total budget If I have say $700 to spend I look at amps around 1-1500rms and see around $350-700 is the going rate so I pick one that is $400( ie sax1200) I then see I have $300 left now that's 2x 150 subs, 1x $300 or even 3x $100 I can get 2 good 12 for $110( ie e12 sundown) So I'm at $620 and that leaves me $40 to build the box and $30 for power wire Or I can do 3x e12 for $730 or e10 $715 If I already have some wood and power cables, or don't mind going a bit over That is how I work out what will fit and work well for what I have and can afford Measure Mock up box Elect system support Total budget Pick a brand your happy with And mix and match until they all fit
Watch the bass Posted April 23, 2013 Report Posted April 23, 2013 Please give us a budget. "in the abundance of water, the fool is thirsty" Bob Marley
