B-Stock Damplifier Pro Is back!
B-Stock Damplifier and Damplifier Pro are just like their A-stock counterparts, except the thickness varies +/-25%, and the foil tends to be a little scratched and dented. It may not be as pretty as A-Stock Damplifier Pro, but man is it effective, and if you're on a budget there's really nothing better!
Check out the products on their specific product pages:
B-Stock Pro Bulk Pack - 30SqFt
B-Stock Pro Shop Pack - 90SqFt
The B-Stock is a byproduct of the manufacturing process of the A-Stock, so once it's gone it's gone until we reorder A-Stock Damplifier Pro. Don't miss out on this, if you're in the market for sound deadening, this is the best deal you'll find pretty much anywhere.
  • 3 weeks later...
When clicking the link for the B-stock pro pack 30sqft it shows the weight at 20 lbs. That seems light for 30sqft even if the thickness is off making it B-stock. Is the weight correct?
Thank you
RB
01 Chevy Silverado X-cab
2 Sundown Z18v4 walled on 2 Lanzar Opti 7k's strapped at 1/2ohm = each amp wired to 1/4ohm. Havent checked impedence rise so not sure what they are actually seeing. 6 group 31AGM's.
2-Eclipse 34230's each one running 2 Eminence 6.5" Beta 6A. These are beastly mids rated at 350w program power. I was skeptical but the eclipse amps are 370w x 2 and when there was 4 mids on 1 amp I could push it into thermal protect within a song so added the 2nd amp.
Eclipse 4212 running 4 CT sounds Meso tweeters. and 2 DLS ultimate tweeters up high to raise the soundstage.
96' Ford F350 4wd 4d long bed 7.3 diesel with 91k miles. Will be the sound quality rig if I can ever find the time.
Thanks for the reply, think its time to order 8).
