1 or 2 amps
gibblegeibel
2 amps will distribute box rise between the two... Just a thought.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Google box rise. You will see its the natural law of when you play a subwoofer in an enclosure even though you wired it to 1 ohm nominal (fake numbers) at 40hz your sub might rise to 3 ohms... Then on 23hz it might drop to 1.1ohms... And on 65hz it might drop to 1.4ohms. Every box has a different box rise and frequencies where it rises.... This also depends on the subwoofer put in the enclosure....
But if you have 1 2000 watt amp and 2 1000 watt amps... Both are made to be wired at 1 ohm... And put out true RMS at that 1 ohm... Lets go back to that 40 hz referenced earlier... You would be seeing 3ohms .... With the 1 2000 watt amp you might be seeing 800rms because the amp is seeing 3 ohms not 1 ohm....
But the 2 1000watt amps would be seeing 1.5 ohms each (3 ohms / 2 amps) they might be making 600 rms each totaling 1200... So 1 amp you might have 800 rms and the two you might have 1200 because of box rise even though both do 2000 total rms at 1 ohm.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
  • Who's Online   0 Members, 0 Anonymous, 902 Guests (See full list)
