need help to chose DD amps
gally
if youre too worried about gain matching why nor just strap them
its not the gain mathing problem...i would wire the 2 amps together...so to strap them is the answer?
2010 Chevrolet Cruze
Radio --- pioneer mvh-200vbt
Sub Control --- Pac LC1
Sub Amp --- GZPA 1.4K
Sub --- GZNW 15XSPL D1
Battery - GZBP 12.2500X
Ill be that guy two m1bs. Chesper. Gain matching isnt that hard. Less rise per amp.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
yeah...i know the M3a gets in my head, but another M1b would be killer for me...other than that i wouldnt wire them to 0,5, i would rather buy a more powerfull amplifier
so each amp will be wired on 2 ohm each...for starters...later with battery upgrades and a another sub then i will strap them each to 1ohm...so 2ohm both
If you running 2 ohms to each amp you will have no problem with 2 m1's.
with later electrical upgrades i would run them to 1 ohm on each amp
strapping them at 2 ohms will give you a final impedance of 1 ohm per amp.. if you wire the 2 subs later at .5 ohm strapped you will toast all your equipment. DO NOT listen to this fool telling you to strap the amps at .5 ohms. it will run each amp at .25
wtf man...as i explained beforei will rather buy a bigger amp than strapping both amps to 0,5 or 1ohm...
i will be however strap the amps so that EACH amp will be seeing wither 1 or 2 Ohms...
  • Who's Online   0 Members, 0 Anonymous, 1044 Guests (See full list)
