box build for 15 inch kicker L7
i am trying to make a box for my brothers 15 inch l7 i want to make a vented box. he has it running on a kicker zx 550.2. hes prob gonna upgrade to a bigger amp soon but for now thats what he has in a 03 monte carlo. i made a box on RE box calculator and this is what i have. please leave ant comments or advice thanks,
box width - 32 inchs
height 15
depth 28
3/4 MDF will be used
port width 5 inchs
port length- 22.25
2 port length- 15
box voluime- 4.5 cubes
tuned to 27 hz
please let me knoiw if this looks good and the tuning is good. i understand the the sub is really big and the sub displacement will bring the volume down but the box seems big enough to me. and the tunning might be a little low. but let me know thanks
Tune is toooooo low
And box is toooooo small
Other then that its ok
Why do you want it tuned so low?
And with so much trunk to work with why so small
i was thinking the tuning was pretty low. when you put the sub in the box does it make the hz change at all? and i was thinking it is pretty big. his trunk dimensions are 32wide, 34 deep, and 16 tall. but would you say around 30 hz would be good?
Post the max measure of his trunk as if box is square or at 90deg all round
What does he want to archive sq, spl mix if both
What music does he like
And how much future power does he plan(idd recommend 1k clean true power
So aim for 1- 1.2k
33 wide 35 deep 16 tall. he wants more sq in this box since the one he has now is loud but has no sq. but i would still aim for both. he listens to only rap and lower hitting songs. he is prob gonna get a hifonics brz 1200. which can give out a clean 1000. i just downloaded torres so if u could help me out with the demensions i would appreciate it
Can you give some meserments of what he has now
As on a l715
I like 7net@37hz 90sq" port but that's for 5-750rms
I did run mine at 1k clean for a while in same box but I wouldn't recommend it
mid 30's tuning. probably like 5-6 cubes.
too low a tuning and the box wont be able to play higher notes.
  • Who's Online   0 Members, 0 Anonymous, 1137 Guests (See full list)
