Tool maker inputs
im trying to decide if theres any real gain or if its worth the extra $70 to go with copper inputs over aluminum.anybody have an idea or actual results between the 2? amp is a DC 7.5k if that matters ...thanks in advance
2000 Suburban 6 runs of 2/0
12 JBL Pro audo mids ,6 timpano audio tweets and 1 Prv compression horn per door
475ah of yin long LTOs
Triple 370 Amp Autotech Alts
mids amps 2  Crescendo Skyway 3ks
compreesion horn amp crossfire 800.4
Tweet amp Crossfire 2000.4
sub amp: 4 Crossfire XT 8ks
Subs: 8 18 in Crossfires in a 4th order
Best Scores at events…
163.5@38hz DBdrag  sealed on the dash… 164.3 outlaw…162.9 Meca headrest
I went with aluminum. I know Snowdrifter is running Copper ones.
Im running 4 of them on a 5.0k
power wire from the rear batts to amp will be about 2-3ft long if that also helps
thats what im thinking of going with since i know i can spend the $70 else where,just wanted to know if there was any real benefit.i know in long power wire runs its different but how much resistance could there be in a big chunk of aluminum vs copper?
This might help you man
They are relatively close.
I got copper. Because YOLO
Lol but actually... It's more conductive. And aluminum and copper react in a process called galvanic corrosion. If there is any moisture - the two metals will corrode themselves
Besides... You have what.... A $1500 sub amp? What's another $20 bucks/input for the copper upgrade
Never knew that. I may just have to go buy some copper ones :good:
perfect this is what i was looking for,i have the wire chart but nothing for actual raw material..thanks bro :drinks:
well since you put it like that Lol
  • Who's Online   0 Members, 0 Anonymous, 1420 Guests (See full list)
