How do you wire a 12v key-hot pigtail?
Just got a mechman s series 240a universal alt, came set-up with a 12v key-hot pigtail.
Was wondering how to wire it up? Help? Please and thank you :D
Here's a couple pics if no one has seen one before
1991 Nissan Pathfinder
Mechman 240A alt
All wire 100% OFC 1/0
Kenwood KDC-X497
Pair of Kenwood Tweets/Pair of Rockford P1 5x7s
9ft3 vented box ~32hz
2 AQ HDC3 copper coil 18s
SAZ-3500 @ 1ohm
Powerbass ASA 200.2
39 sq. ft. damp pro.
Kinetik 1200&2400(x2)
That's why they set it up like that, because the factory plug-in isn't for this alt. Im sure it's internally regulated but i could be wrong as well.
Mechman 240A alt
Kenwood KDC-X497
SAZ-3500 @ 1ohm
Powerbass ASA 200.2
looks like to me you need to find a wire thats hot when the key is in run position and turns off when you cut the key off just my guess
that's the kind of thought thats been running through my head, just need more input before i actually wire it up.
tap into wire from stock harness if its internally regulated just have to find the right one
this has also been a thought as well lol
Mechman 240A alt
Kenwood KDC-X497
SAZ-3500 @ 1ohm
Powerbass ASA 200.2
when i upgraded my alt(not mechman) i had to put a diode to make it work.
something like this. you can also use an idiot light.. if i can find the diagram i will post it
why exactly did you use the diode, if i may ask?
Mechman 240A alt
Kenwood KDC-X497
SAZ-3500 @ 1ohm
Powerbass ASA 200.2
because the alt wouldnt turn on. i plugged it to the ignition and would only get resting voltage. stock cars that dont have an idiot light have a 500 ohm diode to make it turn on. i dint want to look for the wire so i wired the diode and the wire to the ignition and now i get 14.2 voltage
I see, so you also had to wire an external regulator on your alt?
Mechman 240A alt
Kenwood KDC-X497
SAZ-3500 @ 1ohm
Powerbass ASA 200.2
  • Who's Online   1 Member, 0 Anonymous, 1611 Guests (See full list)
