So I had been planning on running 2 VVXv2 12"s in my car, but I was wondering if running a single 15" would have more potential to get louder?
I'm sure the ZVX would blow the other 2 options out of the water, but would I see an improvement of the single VVX 15" over the 2 12" ones?
For what it matters, what I get will be running on a single 800.1D until I'm ready to upgrade, most likely to 1500.1D.
On 2/28/2013 at 2:52 PM, Chaise said:
"Now spread your butt cheeks so I can zap your asshole."
Hell, I'll eliminate the VVX 15.
Should I do 2x VVXv2 12"s or a single ZVX 15"?
If I do the 2 12" VVXs, I would probably buy another 800.1 and master/slave if possible, instead of getting the 1500.1.
Edited by inm
If you have the proper airspace for 2 12's, then 2 vvx 12's, due to more cone area, and motor force.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
2 VVX 12"s even over a ZVX 15?
well, ive heard 2 sa 12s in a buddys truck, then he put in a sa 15. the 15 got a lot louder than the 2 12s. by ear anyway. i know that is sundown, but just a personal experience. but it all depends on what you want outa your system.
93' Exploder
Deck:Pioneer 6400-bt
Front Stage: Crescendo PWX 8"s and Skar Audio VX1-ST per door
Amps: Sundown Audio SAZ-3500 v1 @.375 ohm daily, CT Sounds 125.2
Subwoofer: Two PSI Platform 2 18"s,Fully Loaded D1.5's
Enclosure: B Pillar Fourth Order, 3:1 ratio tuned at 46 (Designed by Low Hertz Box Designs)
Wire: All Sky High Car Audio Cable!
Alternator: Singer 250 amp Hairpin
Batteries: XS Power D975
Team Audio Connections
  • Who's Online   0 Members, 0 Anonymous, 3159 Guests (See full list)
