Hello all, I'm sorry if this has been answered a million times already, but I'm desperate for some knowledge. No luck finding the specific answer i'm looking for. I'm using a line out converter since I want to keep my factory headunit and install an amp and sub.. Anyways, I'm thinking the best place to tie in the converter would be anywhere between the factory sub and amp.
  • The factory amp is rated at 315 watts so do I need a converter that will match that wattage? I ask because I seen a converter rated at 300 watts (150 per channel)
  • Also since the converter is 2-channel and the factory amp only has 1 speaker output (right?) where would I tie in the other channel of the converter, to use the full potential of the converter?
thanks
I would get a Cache Cloc+D or Audio Control LC-1 tap in to both your rear speakers left and right if your concerned about stereo imaging.
2010 Mazda 3s 2.5L
Pioneer DEH-X9600BHS
Knu OFC 1/0
SS Platinum AGM / XS Power XP750
Alpine PDX F-4 / Morel Maximo 5 + Coax 5
IA 10.1 / SSA XCON 12
If you are using High to low level you tap in after the factory amp. Tap in to the wire coming off the speaker.
2010 Mazda 3s 2.5L
Knu OFC 1/0
  • Who's Online   0 Members, 0 Anonymous, 1226 Guests (See full list)
