lionfamlee Posted May 17, 2013 Author Report Posted May 17, 2013 Here is a suggestion: Enclosure Specifications: Fb = 35 Hz Vb = 6 ft^3 External Height = 18.25 in External Width = 46 in External Depth = 22 in Port Width = 24 in Port Height = 4 1/8 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Top & Bottom (3 parts) = 46 x 22 Left & Right Sides = 20 1/2 x 16 Front & Back = 46 x 16 L Port Internal Assembly Parts: Front to Back = 16 3/8 x 25 1/2 Extension = 3 1/2 x 25 1/2 Port Left Side Assembly: 16 3/8 x 4 1/8 8 3/8 x 4 1/8 Port Right Side Assembly: 16 3/8 x 4 1/8 8 3/8 x 4 1/8 Assembly guide (generic dimensions): Important notes: - The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know. - All boxes built outside the car need to fit in their way in not just have the right dimensions. - The port needs 4 1/8" of free airspace in front of it for proper operation. - Setting your amp subsonic filter to 28Hz is suggested. I will be building the box in the morning. Could you show me the plans for the 45's. Thanks
Joe X Posted May 17, 2013 Report Posted May 17, 2013 Never mind that message as it's applies only for boxes in which the sketch shows 45s, but seek to sand all inner edges of the port.
lionfamlee Posted May 23, 2013 Author Report Posted May 23, 2013 Woooooo! Box built and installed and it sounds awesome! Thanks Joe X!!!
lionfamlee Posted May 24, 2013 Author Report Posted May 24, 2013 My wife liked the design and most importantly the sound. She wants me to put two 12's in her can. Would you recommend subs up and prt back in a mini van?
lionfamlee Posted May 28, 2013 Author Report Posted May 28, 2013 So what would be the specs for the 6 memphis subs set up? I know you said to tweak the box a bit, but I want to make sure it is correct. I got a deal on a second 350 amp alternator so I will be able to run to AQ 3500 on the other 3 mojos I have. Thanks JoeX
lionfamlee Posted October 4, 2013 Author Report Posted October 4, 2013 Hey JoeX could you please design a enclosure for six of the subs mentioned above (Memphis Mojo), going in the same car?
