carsonbakr Posted May 9, 2013 Report Share Posted May 9, 2013 Bought an SA-15 for my Ford Explorer. I've been looking around the internet and no one really has an enclosure design for just one SA-15. I'm going to be pushing about 1k and want it to be tuned at 32 hz for rap. Can anyone help with an enclosure design because I got turned down by RAM designs (due to lack of time he has) and I really don't want to have to pay $60 for a design by Pete. Thanks. Quote Link to comment Share on other sites More sharing options...
DylanBunch Posted May 20, 2013 Report Share Posted May 20, 2013 Bassheads ent? Quote 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows Link to comment Share on other sites More sharing options...
HunterJohnson Posted May 20, 2013 Report Share Posted May 20, 2013 I'd do it 3.2 cubes net 12" of port tuned to 35hz Quote Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass Link to comment Share on other sites More sharing options...
DylanBunch Posted May 20, 2013 Report Share Posted May 20, 2013 I'd do it 3.2 cubes net 12" of port tuned to 35hzIdk, my friend has a sa 12 at 12" port per foot and like 5-6hz under tuning the sub moves a lot but it loses its bass sound.... just kinda sounds like motor noise. But that might not have to do with the port specs, idk Quote 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows Link to comment Share on other sites More sharing options...
Nightshade Posted May 22, 2013 Report Share Posted May 22, 2013 (edited) I have built several enclosures for Sundown subs but never the sa15s. I have mostly done Nightshades and usually go with 3 cubes after displacement with about 8.5 sqin of port per cuft. For the sa I would do 2.5 cubes with 2 4" aeroports tuned to 35-37 hz. This will give you 10 sqin per cuft. Also the reason for tuning higher will keep the sub safe. I have broken the triple joint on the sa12s by tuning low. The sub is not made to move to to the extent that 32hz demands with a lot of power. This will save you some trouble in the long run. Edited May 22, 2013 by Nightshade Quote 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz Link to comment Share on other sites More sharing options...
