jarrius Posted May 13, 2013 Author Report Posted May 13, 2013 If you are going for "SQ" like the title says ... Then you should be tuning more around 24 to 28 htz ... Just saying ... I love the fact the name changed like that, cuz when people ask what I have "in there", I say, "Just a lil "SQ" setup, that's all." LOL Omg I can just see there faces when they see/here what you actually have lol 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
jarrius Posted May 13, 2013 Author Report Posted May 13, 2013 So here is a suggestion: Enclosure Specifications: Fb = 36 Hz Vb = 2.5 ft^3 External Height = 15 in External Width = 37 in External Depth = 15 in Port Width = 3 1/4 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Front & Back (3 parts) = 37 x 15 Left & Right Sides = 12 3/4 x 13 1/2 Top & Bottom = 37 x 12 3/4 L Port Internal Assembly Parts: Front to Back = 9 1/2 x 13 1/2 Extension = 14 1/4 x 13 1/2 Assembly guide (generic dimensions): Important notes: - The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know. - All boxes built outside the car need to fit in their way in not just have the right dimensions. - The port needs 3 1/4" of free airspace in front of it for proper operation. - Setting your amp subsonic filter to 28Hz is suggested. How far do I put the woofer from the port? 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
Joe X Posted May 13, 2013 Report Posted May 13, 2013 As far as possible from the inner end of the port is the better place.
jarrius Posted May 13, 2013 Author Report Posted May 13, 2013 As far as possible from the inner end of the port is the better place. so that would be close to the actual port slot it self. sorry for the noob questions btw 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
Joe X Posted May 14, 2013 Report Posted May 14, 2013 I would expect no problems if placing it about where you see it on the sketch.
jarrius Posted May 14, 2013 Author Report Posted May 14, 2013 Ok thanks a lot and once again I'm sorry for the noob questions man and thanks for your help so far 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
jarrius Posted June 1, 2013 Author Report Posted June 1, 2013 So I made a miss measurement on how tall my box can be. Max for how tall it can be is 14 in. (15 makes it hit the arms of my trunk ) so if I take off 1 in and make it External Height = 14 inExternal Width = 37 inExternal Depth = 15 in will it change much and I assume the cut piece will change to 2 x Front & Back (3 parts) = 37 x 14Left & Right Sides = 12 3/4 x 12 1/2Top & Bottom = 37 x 12 3/4 Front to Back = 9 1/2 x 12 1/2Extension = 14 1/4 x 12 1/2 please correct me if I am wrong and if itwill change tuning and stuff like that. 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
Joe X Posted June 1, 2013 Report Posted June 1, 2013 It would reduce net volume and up tuning, anyways in the design post above I changed dimensions so that your box can be 14 high and still keep the original spec.
jarrius Posted June 2, 2013 Author Report Posted June 2, 2013 It would reduce net volume and up tuning, anyways in the design post above I changed dimensions so that your box can be 14 high and still keep the original spec. thanks man that's why I wanted to ask and see what it would do. I am no box expert at all lol don't really know how to figure it out for my self. thatsthe next thing im going to learn 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
jarrius Posted June 3, 2013 Author Report Posted June 3, 2013 With me dropping the power from 750rms daily and 2k during comps to 1200 all the time make a difference in the size of the box? 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
