SQ HDC3 12 box design help
jarrius
So finally ordered my AQ/SQ HDC3 12 for my sonic and I have tried to design my own box with Torres and I cant fugure it out with the port and tuning.( need to play with it more). So with that said can I get some help. it will be in a trunk single 12 facing forward and port forward on about 1k-2k depending on what I am using it for at the time. Max numbers I want to use is this 24Lx37Wx19H tune to about 35 HZ if that's to low just let me know ^_^ . as long as in it with in that range I should be able to get it in and out of the trunk through the trunk door... I hope lol. If any one can help me that would be superb since I don't want to mess up the woofer or waist money on the box.
Also what material will I need. I know MDF or Burch bord for box but what type of glue and all that for making sure it stays together.
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
You can use probably any good wood glue but I recommend Titebond II. I hear some people use Elmers wood glue with good results too but I always use Titebond II. Used Titebond I once and it worked good too. The Titebond II is moisture/water proof though.
ok I will try that
141 on music.
If you are going for "SQ" like the title says ... Then you should be tuning more around 24 to 28 htz ...
Just saying ...
He means sq as in soundqubed audio instead of audioque
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
SQ as Soundqubed
Just saying ...
141 on music.
I stand corrected
All good man.
141 on music.
So here is a suggestion:
Enclosure Specifications:
Fb = 36 Hz
Vb = 2.5 ft^3
External Height = 14 in
External Width = 37 in
External Depth = 15.75 in
Port Width = 3 1/4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Front & Back (3 parts) = 37 x 14
Left & Right Sides = 13 1/2 x 12 1/2
Top & Bottom = 37 x 13 1/2
L Port Internal Assembly Parts:
Front to Back = 10 1/4 x 12 1/2
Extension = 11 1/2 x 12 1/2
Assembly guide (generic dimensions):
Important notes:
- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.
- All boxes built outside the car need to fit in their way in not just have the right dimensions.
- The port needs 3 1/4" of free airspace in front of it for proper operation.
- Setting your amp subsonic filter to 28Hz is suggested.
Just saying ...
I love the fact the name changed like that, cuz when people ask what I have "in there", I say, "Just a lil "SQ" setup, that's all." LOL :)
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
  • Who's Online   1 Member, 0 Anonymous, 3289 Guests (See full list)
