Alternator size help
I will be getting a soundqubed 3500.1 amp with a 380A inline fuse, so I need to know how big of an alternator I need to get.
02 Lexus IS300 (2JZ FTW)
Mids/Highs: JL Audio C5 6.5s all around
Mids/Highs Amp: JL Audio HD 600/4
Subs: four SA-8v2s in 3.8cubes @ 32hz
Sub Amps: SAZ3k
Battery: Huge Interstate Batteries relocated to trunk
About 80ft. of 1/0 OFC....
Head Unit: Pioneer 4200NEX
i got a 230 amp alt and kinda wish i went bigger so i would have room for a bigger amp down the line but i was to stoked and jumped on it before i really searched around
I probably won't upgrade my amp lol and not bare minimum. Just enough and then some, know what I mean?
Sub Amps: SAZ3k
97 Nissan maxima
Sub Amps: SAZ3k
its better to spend more money on alt and get less batteries in the trunk, since it's sedan car!
edit:
basically bigger is better
sometimes Loud is NOT pretty
Sounds like its safe to go ahead and bend that ass over.
edit:
I agree with the above statement.
Chevelle%20Team%20Cover%20without%20RE%2
^Vehicle log to come soon for this.^
Would a 250Amp be sufficient?
Sub Amps: SAZ3k
P(W) = V(V) × I(A)
power in watts is = to volts times amps
so re-arrange it to power/volts=amps
3500(watts)/(14.6Volts)= 239.73 AMP
so to answer your question, a 250 amp alternator will be sufficient, yessir
EDIT: unless you're running at 16V, which would be crazy. but if you were, just plug it into that equation, which would be : (since the site says it does 5300 @ 1 ohm on 16V) you would do: 5300/16 = 331.25amps.
2006 Monte Carlo
Pioneer DEH-80PRS
2 SSA ZCON 12's
5 Cube Box tuned to 32 Hz
Soundqubed 3500.1
PAC LC-1
Singer 320 Amp Alt
XS D3100 & Kinetik HC2400 in trunk
Super Start AGM Under Hood
80ft+ Sky High 1/0
40 ft^3 120mil sky high deadener
Soundqubed Pro Audio 6.5" mids
Soundqubed Super Tweeters
Alpine 1" Tweeters
Alpine MRP-F300
So 250A would work, I found a 250Amp USA alternator on eBay for $230, would that be a good choice or should I get Mechman, if I get Mechman, I'll bump up to the 270Amp version.
Sub Amps: SAZ3k
  • Who's Online   0 Members, 0 Anonymous, 943 Guests (See full list)
