bassinyerface Posted May 14, 2013 Report Posted May 14, 2013 So i got in my truck yesterday and started bumping pretty good. And a high note came in the decaf version of atlanta zoo and my subs make this weird loud rattle i immedialty turned it down and checkd everything out. Everythings fine my subs seem to have less output ever since yesterday and idk why. It stil rattles btw only on high notes thinit slams the lows still. 2003 f150, 2 ab hd 15 on brutus 2400.1, kinetik batt, big 3, knu wire, image dynamics cxs 6.5 with ppi tweets, pioneer 1din and clarion eq.
bassinyerface Posted May 14, 2013 Author Report Posted May 14, 2013 Btw is it bottoming out? Idk it sounds like it do me but wouldn't also be making the noise on the lows to? 2003 f150, 2 ab hd 15 on brutus 2400.1, kinetik batt, big 3, knu wire, image dynamics cxs 6.5 with ppi tweets, pioneer 1din and clarion eq.
big dee Posted May 14, 2013 Report Posted May 14, 2013 What kind of subs? What amp? And also are you sure it's not something rattling in your car? I've had issues like this before . Then later on switch setups an that same noise again. Lol turned out to be trim panels or window trim resonating on certain frequencys
evermaxx Posted May 14, 2013 Report Posted May 14, 2013 Look in his sig.. Sundown E15 (x2) Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench
big dee Posted May 14, 2013 Report Posted May 14, 2013 The sounds can fool you easy Nd come from the front and sound just like its coming from the back. Shit drives me nuts
big dee Posted May 14, 2013 Report Posted May 14, 2013 Look in his sig.. Sundown E15 (x2) im on mobile can't seevit
bassinyerface Posted May 14, 2013 Author Report Posted May 14, 2013 Ok well ill forsure check to make sure its the subs not anything else. 2003 f150, 2 ab hd 15 on brutus 2400.1, kinetik batt, big 3, knu wire, image dynamics cxs 6.5 with ppi tweets, pioneer 1din and clarion eq.
bass juggernaut Posted May 14, 2013 Report Posted May 14, 2013 i had 2x Zv.2's that did the same thing, it was my speaker leads in the box touching each other (banana clips)
big dee Posted May 14, 2013 Report Posted May 14, 2013 And the drop your feeling in the output could be the subs loosening up .
SnowDrifter Posted May 14, 2013 Report Posted May 14, 2013 You sure it's your subs and that you don't have a bad box? ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
