john253a Posted May 15, 2013 Report Share Posted May 15, 2013 Been asked to do and install on a 62vett and keep it looking fully stock Car has a single 6x9 fitted in the centre of dash factory And previous owner switched it out and fitted 2x 4" 2way in there The owner was looking at the morel tempo-69c And only using 1 of them But I've susgested sticking with 2 round speakers He has a factory copy aftermarket h/u witch can select 1,2,3 or 4ch and is 45w @4ohm x4 So to most of what he has and keep that factory look I was looking at coaxel components or coaxel with crossover that can be bi-amped About 4-450 is his limite (5-550 shipped to aust) 4-5.25" only please Something along the line of this what I'm after But to maximise output I need bi-amp as well witch this doesn't have https://www.woofersetc.com/p-11275-hybrid-integra-502-morel-525-2-way-coaxial-speakers-with-passive-crossovers.aspx So any help on anything that can be bi-amped and coaxle mounted in >5.25" would be grateful thanks Link to comment Share on other sites More sharing options...
Kevin M Posted May 16, 2013 Report Share Posted May 16, 2013 http://www.parts-express.com/pe/showdetl.cfm?partnumber=296-723 http://www.parts-express.com/pe/showdetl.cfm?partnumber=264-913 Some other 4" fullranges to look at http://www.madisoundspeakerstore.com/approx-4-fullrange/ No crossovers, or crossover points. They can maximize the low wattage. One speaker to play the whole range. I would recommend a high end comp set but for the equivalent of deck power I would run a full range instead. 2005 Ford Focus zx4 AMT's and Planars 18" Infinite baffle Link to comment Share on other sites More sharing options...
