Quick question for guys that have run quad Alts
Ok, so I have an 08 Suburban with quad Singer Alts utilizing the DC quad bracket. Now my question is: there are no grounding posts on any of the Alts. So A) do I send them back to Mike to get ground posts put on, B) do I have my friend just solder a post onto the bracket, or C) do I just get a larger bolt for the alt sticking the furthest from the engine so I can have extra thread on the backside of the bracket to sandwich the runs of 1/0 between?
Any input is appreciated and pros/cons to each scenario.
Thanks!
well... you cant solder a bolt onto the case.
you could send them back to mike and or just put the terminal on the alt. mounting bolt
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Not onto the case brother. Grind down to bare steel on the bracket, tac it and re-spray after.
the engine block is grounded from frame to battery or engine block to battery your bracket is bolted to the block no need for grounding post on your alternators i just beefed up my grounds i put two 0/2 welding cable from frame to engine and engine to battery thats what i did
really? have you ever seen how little material there is between the engine and body?
just use the bolts that bolt alt to braket and be done with it!
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
I hear ya there but the problem with that is the OEM bolting location for where the bracket secures isn't very tight... In fact it had these rusted metal spacers in there that were a PITA to get out but I replaced them with stainless washers but I'm sure there's still gap in that to a certain extent.
I planned of course to upgrade the block to frame grounds already and run dedicated from front batteries to frame as well but didn't know if beefing up the alt ground point would be a significant difference.
i guess you could mount a grounding post it would be a good idea i dont have any issues voltage drop or anything
  • Who's Online   0 Members, 0 Anonymous, 1360 Guests (See full list)
