ok i got a DMM but do not know where to put it so i can set my gain i got
dcv/500/200/20/2000m/200m
then i got ohms/2000k/200k/20k/2000/200
dca/200m/20m/2000u/200u
acv/500/200
and do i have to play a tone to set it ????? b/c i can not seem to find a please to download it right off of 50hz tone
and do i test at the speaker terminals of the amp and do i have to have the subwoofers hooked up????
put the vol at 3/4 of the way up and turn the bass knob all the way up on the dash?????
ok get this straight u do not use the bass knob for anything other than showing off or on a tone burping. it is not a set and leave thing it is remote bass. when its not being used it is turned all the way down
now u wanna set ur dmm to acv. not sure on the 500 or 200 though
a 50 hz tone can be downloaded from realm of excursion. go to downloads and look for a little bit and ull find it.
u test at the speaker terminals and no the subs should not be hooked up.
put the volume at 3/4 on the head unit. gains all the way down on the amp.
then turn the gains up until u reach the voltage u need for ur rms wattage
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
gotcha now i need to find out where my plugs got on my DMM i got a 10adc first plug 2nd ons is v ohm ma 3rd is COM i got a red and black tester
u gotta wait for someone else to answer that cause im not familiar with a dmm
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
well i got my plugs in the right way now i my DMM but now i still can not download a tone b/c realmofexcursion.com i can hear it on windows media player but i can not download it for some reason it says it has errors
well try back 2morrow
i dont know of another site that has tones
just do a search on google c wut u come up wit
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
welli finally got a 50 hz test tone and played it at hlaf vol and turn the bass knob all the way up and then adjusted the gain on the amp untill it said 71 volts and that makes the gain be at like 1/4 of the way up is this correct????
i just do not understand it it has all the rest of the gain to be turned up why do i keep the gain on 1/4 of the way up
here is the DMM
when i set the gain on my amp
Posted Image
also for 2500 wrms ur lookin for about 70-71 volts @ 2 ohms
that is about right on ;)
you answered it yourself. you said you have the bass knob turned all the way up. that's why you dont need so much gain. turn the knob down, and then you'd need to turn the gain up some more. honestly...i wouldnt even use the bass knob. i control it from the cd player which is easier imo. also helps me make sure i stay away from any distortion cuz i definitely dont wanna blow up my shit. if you got 70-71 (70.71 to be exact ;)) then yeah that's fine...with a 2 ohm load on the amp, that's how you want everything adjusted regardless of how much extra gain you can turn up or however much power you want. if you want more power, you're gonna need another amp. turning it up higher will result in a clipped/distorted signal and blow the amp and/or the subs.
also...when you set that...was the volume turned up to 75-80%? and bass/treble/any other settings turned to 0?
