could someone please spare 5 mins to look at these figures :)
TUNES
boot area is maximum
width 39.5"
height 20"
depth top 31.5
depth bottom 39.5"
Ok, here is a suggestion for 4 of those, it can be changed if necessary:
Enclosure Specifications:
Fb = 32 Hz
Vb = 7.8 ft^3
External Height = 18 in
External Width = 39.5 in
External Depth = 30 in
Port Width = 28 in
Port Height = 3 1/2 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Top & Bottom (3 parts) = 39 1/2 x 30
Left & Right Sides = 28 1/2 x 15 3/4
Front & Back = 39 1/2 x 15 3/4
L Port Internal Assembly Parts:
Front to Back = 22 3/8 x 29 1/2
Port Left Side Assembly:
22 3/8 x 3 1/2
Port Right Side Assembly:
22 3/8 x 3 1/2
Assembly guide (generic dimensions):
Important notes:
- All boxes built outside the vehicle need to fit in their way in not just have the right dimensions.
- The port needs 3 1/2" of free airspace in front of it for proper operation.
- Setting your amp subsonic filter to 28Hz is suggested.
- Top to bottom brace is 1 1/4 wooden dowel rod, port brace is just 3/4" MDF as the rest of the box.
hey joe that looks awesome but what if i asked if it could be 39.5 wide and 19 high? depth can be whatever it needs to be
Changed to 39.5", however if I make it taller it would need loose depth to stay the same volume. I need the depth for port clearance to the backwall.
thats ok buddy, could i put the box on 1" raisers so would allow cables to run underneath?
Hey joe sorry not been on, been loaded down with work. Ive imported a circle jig from the states and waiting for that to turn up so I can build that box nice and properly. Would it make a difference if I countersink the subs?
No problem, unless you were to use higher power subs later, flush mounted subs are a little harder to remove though.
  • 1 month later...
hey buddy hope you good, i been so busy and ill that ive only now started looking properly at starting your box design
when i calculated the dimensions, it comes out at 12.34cuft? and i need about 7.5-8ish or am i calculating something wrong....as usual lol
ive measured the cargo area again of my wagon which looks like this
https://www.google.co.uk/search?q=passat+estate&rlz=1C1KMZB_enGB535GB535&um=1&ie=UTF-8&hl=en&tbm=isch&source=og&sa=N&tab=wi&ei=emDMUZS_Fc_d7QaKv4DQBA&biw=1280&bih=699&sei=fWDMUabmJsGj0QWd4YHYCA#um=1&rlz=1C1KMZB_enGB535GB535&hl=en&tbm=isch&sa=1&q=passat+b5.5+estate&oq=passat+b5.5+estate&gs_l=img.3..0j0i5.15321.17445.0.17539.5.5.0.0.0.0.60.236.5.5.0...0.0.0..1c.1.17.img.Zk-llvT5ZZI&bav=on.2,or.r_qf.&bvm=bv.48340889,d.d2k&fp=babc8f03de927268&biw=1280&bih=699&facrc=_&imgdii=_&imgrc=B49lff0lPfujLM%3A%3BL8Agj8dErhFnGM%3Bhttp%253A%252F%252Fsphotos.ak.fbcdn.net%252Fhphotos-ak-snc4%252Fhs279.snc4%252F40291_1334281606914_1527270049_30770571_5744141_n.jpg%3Bhttp%253A%252F%252Fwww.ukpassats.co.uk%252Fphpbb%252Fviewtopic.php%253Ff%253D8%2526p%253D210536%3B720%3B480 sorry for silly link length :(
and cargo area i have to play with is 39.5" w, 20" h and 30"d
i have a sq up front and i would like the box to be for spl when i want to really bump it hard
i want to use 4 of these http://www.jbl.com/estore/jbl/us/products/GTO1214/GTO1214_JBL_US
and 2 of these http://www.jbl.com/estore/jbl/us/products/GTO14001/GTO14001_JBL_US?searchMode=refurbishedProductOnly
sorry for the long ass message but im ready to build and just wanted to double confirm original numbers were correct as it looked a massive box for 7.8cuft lol
hope to hear from you soon buddy :)
Checked with Torres gives similar results, I can guarantee at least it's not 12.34 cubes net.
  • Who's Online   0 Members, 0 Anonymous, 960 Guests (See full list)
