Starter Clicks Several Times and then the Car Evenually Starts!!
This is my car starting right up last night, no problem!
http://s1089.photobucket.com/user/Caraudio1990/media/VIDEO0002_zps412b4b74.mp4.html
This is my car 20 mins ago for the first time today (only two clicks from the solenoid then it started)
http://s1089.photobucket.com/user/Caraudio1990/media/VIDEO0004_zpsec3edc65.mp4.html
...I tested the battery before trying to start it to see what the voltage was.. 12.78V
(2007 Chevy Tahoe LT)
Mechman 320A
OEM AGM
D'Amore Engineering HLC-2 Sig Converter
D'Amore Engineering E1500.1
Fi Audio Neo 3.5 12"
subaru's are known for this ( i know you dont have a subaru) its the contacts in the starter solenoid. the copper contacts wear out and they will work sometimes and not work other times.....my car does this sometimes and my connections are clean and corrosion free.
i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it
Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks.
/ LOL
My Low Budget Build:
Green 1995 Subaru Legacy wagon 147k- $1K
headunit- pioneer premier deh-p650-$25
4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50
4 vvme L11 10"s <- $30 shipped a piece
6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more
2 aspm 1300 strapped
Selenium 6"s in the front doors on headunit power- for now -$20
quantum tweets in door-for now -$10
boston acoustic 5 1/4 in rear doors- for now-Free
big 3
1/0 and 4awg throughout.
roof sound deadened (not peel n seal ftw)-free
on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test
about $430 for everything<----Not bad at all
still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
Its the starter solenoid contacts, they need to be cleaned. Drop your starter take it apart and sand the contacts and itll be good as new.
The spot with least resistance LOL.
I would ground to a rubber dildo if it had less resistance than a run of 4/0 wiring.
how many poeple work there 3 or 4 lol
At crescendo HQ? probably 2-3
At the sweatshop in china? 30,000 children
No Engine
The starter seems like a bitch to get to. I'll see how hard to is to take out and if that doesn't fix It. I'm just going to replace it.
Mechman 320A
OEM AGM
replaced the connections...new terminals, strip back both the power and ground wires, bought a hold down for my battery and it gave my issue at first, but it seems to be starting up every time now (knock on wood......ok did it) so I think my starter is good.......for now. I'm going to buy another newer battery just for extra measurement.
Mechman 320A
OEM AGM
  • Who's Online   1 Member, 0 Anonymous, 1273 Guests (See full list)
