need help now
Port length is determined by measuring from the MIDDLE of the port opening to the back wall, staying half the port width of the back of the wall and then continuing 90 degrees for the rest of the length, while still staying in the middle of the port opening.
I did all you said. but my entire 17.50'' stops at the line comeing off the mdf
Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL
Because you can not GO 17.5" to the back wall, you can only go 14.25 to keep a 3" distance of the rear wall. and then make your turn
i understood i stay the width of the port from the back
this part i got. then i connect from the line going down center and along the back wall 3.25 and the wood should stop there
im following this measuring everything down the center not the end of the port
Screenshot_2013-05-18-20-11-49_zps87bb0e
1 thing, i think im getting wrong. it this correct? the actual port is cut in wood and the port leght is measured in the center
I believe you're on the right track now. Yes the PHYSICAL port length is going to be different than what your wood is cut at
Thankz bro I was going at it backward
  • Who's Online   0 Members, 0 Anonymous, 2193 Guests (See full list)
