Homemade Super-Neo Woofer: THE CHEVELLE RESTORATION IS DONE, dampener recommendations??
Is there a reason you have the leads on the BOTTOM of the spoder pack?
Soldering them can be tricky as well.
As far as gluing.. Place the coil in a jig, or place spider where ever you need it, then glue the bottom side to coil. Then put glue on the spider lip ( where the OD of spider meets the other one) an also where the ID of spider meets the other spider. Keep stacking spiders till you get however many on your using, THEN use your acctivator.
Bassiclly youll have glue around coil And then on the outer edge where spider meets basket. Once those glue joints are done, then you can put a healthy amount of glue on the bottom of spider pack. Then once you get the cone on, you can use a healthey amount where spiders/coil/cone meet (tripple joint)
Hope that made sence
No definite reason but you don't usually see the leads on the finished product, they usually have them in between the spiders don't they? If it made more sense I could have them on top.
basically put on 1 spider, glue the inner ring to the coil, then glue the outer ring, place the next spider on with glue on it's inner ring too, repeat?
So when thats done and I have the pack, do I only need to glue the bottom one only? so I'll have 4 spiders in one stack, but I only glue down the bottom one to the basket? Or do I need to sandwich them with something to hold them down?
The spider leads to not get soldered to the coil leaded until all of the spiders are installed and glued down. Send me a PM and I will give you my number to better explain it.
still got your # from the amp sale
Biomedical/Behavioral Science Major, The (Self-Proclaimed) Undisputed-Homemade-Woofer-King
Super-Neodymium-Woofer Build Log: The D4BA-V.2 http://www.stevemeadedesigns.com/board/topic/169236-diy-super-neodymium-woofer-build-log/?p=2475620
Fucking love Alan you goddamned fucking super nerd lol
When Alan uses big words I don't understand
It's warming up enough that the donut-punching cyclist douchenozzles are getting their two wheeled fagmobiles out.
Everytime I see a guy driving a mini cooper I cant help but think he loves cock & (2/29/16)-My wife just bitched at me about throwing out things we don't really use. My response of well we don't really use your vagina so should we throw that out was evidently not the right response. I had to leave the room.
I missed Alan.
RIP 5/29/15 - I love you son.
Leads are either ontop of spiders or between them ( when spaced) How would you attach the leads to the terminals of they were under the spiders?
1. Place first spider on coil. Glue BOTTOM side and acctivate it.
2. Put glue on coil where next spider will sit. Also put glue on the outer edge ( Opposite side that will be glued to basket
3. Repeat that till you have all 4 spiders on.
4. Clamp the outter edge, the inner edge will be tight from being "forced" into place on the coil
5. Acctivate the glue joints now. If you do it before the glue will be dry and spiders wont "interlock"
The once cone is on, you can add more glue at the tripple joint.
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Oh my... so when does mass production begin?
Tell you what, I'll give the first 100 orders wholesale pricing. You got $2,271.00? lol :D
Time to start saving lol
Well mine could be under because there's 2 levels of spiders. To increase linearity I have 1 set of 4 9" linear roll spiders, then I have the single 10" spider with the quad leads, so if I wanted to I could run them under and then out through holes in the step downs. But I'll just use the holes the basket came with to run the 8ga direct leads.
Where should I get some real nice 8 ga? SkyHigh doesn't have any on their ebay sight.
Do I need to apply a lot of activator ir will it work with just a few good sprays all around?
I missed Alan.
To much activator and glue is brittle just a few sprays is good then let it sit for 24hrs (ive played recones 15min after reconing tho)
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Cj18 sells SkyHigh 8AWG OFC in speaker wire format
523385_10200874355198524_1752022166_n.jp
"Walmart Where Car Audio Is Both Funny and Sad" "The weak are meat, and the strong do eat..."
That would look hideous for direct leads. Better to use power wire 8awg ofc to have a clean jacket.
2003 Tahoe
dc 7.5k
dc level 5 15's (3)
MMats 341's
xs power batts
lots of sky high cable
dual alts(came off the sky-high gmc and don't know who made them)
ipad in center console
vu-din in center console
all being ripped out and being sold
what would look hideous? The plan was to use 8awg direct lol
I missed Alan.
