Okay so you're going with only 2 10's??
You have 5.5cubes before displacement with the volume you posted. I would strongly recommend something bigger. You can fit 2 twelves, a 15" possibly 2 if those aren't you maximums. or get the 18". Unless you are looking for a 2 cube box for saving space why not go bigger?
And addressing what Emmet pointed out, 10's in a correct enclosure won't sound any better quality wise than 12's, 15's, or 18's in correct enclosures.
Edit: Evil post :noevil:
Edited by Krakin
Krakin's Home Dipole Project
What would happen if I tuned it at 30 Hz? :D
The lower you tune the flatter the sound becomes.. I only see this good in home audio.. In a car you want to to bang with some lows so 35-40 hz would be best..
Vehicle: 2005 Kia Sorrento Ex
Head Unit: Samsung Galaxy Note 10.1
Mids & Highs: Motorola KSN-1005s & Alpine SPR-17C Type R 6.5s
Speaker Amp: Sony XM-ZR1252
Sub Amplifier: Pure Audio 3000.1
Subwoofer: Incriminator Audio Death Penalty 21"
So 35 or 33 Hz?
02 Lexus IS300 (2JZ FTW)
Mids/Highs: JL Audio C5 6.5s all around
Mids/Highs Amp: JL Audio HD 600/4
Subs: four SA-8v2s in 3.8cubes @ 32hz
Sub Amps: SAZ3k
Battery: Huge Interstate Batteries relocated to trunk
About 80ft. of 1/0 OFC....
Head Unit: Pioneer 4200NEX
It depends on the subs requirements on how big u need the box but remember the bigger the box the better the lows but at a cost of losing some upper bass frequency..
And cause I like 10s better, they sound better in my car. I just like em more. I might upgrade to the 18 when I get bored though! So the box for the 10s is gonna be 4 cubes @ 33Hz?
Sub Amps: SAZ3k
I would say 33 hz for a balance in sq and spl.. You will get the lows you need for rap with some bang.. But go for 35 hz if u want a lil more bang than lows..
OK but don't forget 4 cuft before displacement.. So your box will really be like 5.5-6 cuft total..
How do I account for displacement? I'm gonna make a kerfed port and do 45s in all the corners, two front plates with an extra one to make em look sexier, and possibly some extra bracings. Once I get it designed I'll put it up with the specs I used and you guys can tell me if it's okay? I wont be back in town until Friday night. You guys have any advice or help with designing it further?
Sub Amps: SAZ3k
No not 4 cubes for (2) 10's! Based off the Zv3 the recommended volume for (1) 10 is 1ft3 after driver and port displacement. (2) 10's would be 2ft3. Putting two of those woofers in a box double their suggested volume is a sure way to destroy them when being ran at RMS.
Remember only build a larger box if you are running on lower power. The higher the volume the less control you will have of the sub at higher power causing it to bottom out, and yes I know the Zv4 has an insane surround.
Higher Power = smaller volume
RMS Power = Suggested volume
Lower Power = Larger volume.
You will get more bottom-end and more benefit by using a box a little larger.
  • Who's Online   1 Member, 0 Anonymous, 594 Guests (See full list)
