Amart88 Posted May 30, 2013 Report Posted May 30, 2013 I was just out working on my truck, I removed a chunk of carpet to bolt some 2x4's I noticed that one of those plastic "grommets" had rusted out and was loose. It's right undet where the rear seats were. When i pulled it off There was some insulating material underneath and I can now see my garage floor. What would be the best way to fix this? A replacement plug is not an option. My 2005 s10 blazer build. 4 zcon 18's walled.
Tebo Posted June 16, 2013 Report Posted June 16, 2013 I used sound deadener on the inside aluminum tape on the outside and sprayed the area with truck bed liner. Still holding up. 04 dodge dakota ext cab 4x4 excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
