Need Spl Box HELP
Good Day ALL
I need help with an enclosure for two 12" Starsound Subwoofers. I want to compete in SPL events, any suggestions on design, tuning, port type would be much appreciated. Thanks in advance
Subs are 1.5ohm dvc 1000w rms
Amplifier is 3000rms Starsound D7000
I have 3 NSB 170AH batteries
0 gauge cable with big 3
Vehicle is a Toyota tazz Hatch ( resonant freq is 47-49hz ) Maximum trunk size is 16x38x18inch
subs Details:
Fs (free air resonance) 38 Hz
SPL(efficiency, 1W/1M) 88 dB
Nominal impedance Dual 1.5
Qts (total speaker "Q") 0.43
Qes (electrical "Q") 0.5
Qms (mechanical "Q") 2.98
Vas (equivalent compliance) 27 L
Mounting Depth 225 mm
Mounting Hole Diameter 286 mm
Tune higher up, and have more port area than a usual box would. The more square you can get the port the more efficient it will be. Aero ports would be the most efficient.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
I'd do 2.5 - 3cube net tune around 45hz... With those dimension, you have planty of room.
My Build Log- T E A M S U N D O W N A U D I O -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
  • 1 month later...
  • Who's Online   0 Members, 0 Anonymous, 1906 Guests (See full list)
