1991 Z28 with 2 SAv2 D4's
I was trying to work out an enclosure for my 1991 Z28 on Torrez and couldn't seem to work it out. I have a 6" aero port that I thought about using but the tuning would be way too high, that is if I was using Torrez right. I also tried 2 4" ports with pretty much the same results. The area I have to work with is L30xD11xH14. I am putting it in the spare tire area/cargo area with the subs and port(s) facing up.
Any suggestions? I am actually going to post a build log here for once.lol Thanks in advance for the help.
Airborne
edit=forgot to mention that I want it tuned to 32hz or so...
If you want sub and port in the same face I would recommend something like this:
Enclosure Specifications:
Fb = 34 Hz
Vb = 1.3 ft^3
External Height = 13 in
External Width = 29.5 in
External Depth = 13 in
Port Width = 2 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
Front = 26 3/4 x 11 1/2
Back = 29 1/2 x 11 1/2
Left & Right Sides:
Side 1 = 11 1/2 x 11 1/2
Side 2 = 12 1/4 x 11 1/2
Top & Bottom = 29 1/2 x 13
L Port Internal Assembly Parts:
Front to Back = 9 1/2 x 11 1/2
Extension = 22 3/4 x 11 1/2
Assembly guide (generic dimensions):
Important notes:
- This box should be operated around subwoofer(s) rated power. If that´s not the case, let me know.
- The port needs 2 5/8" of free airspace in front of it for proper operation.
- Setting your amp subsonic filter to 28Hz is suggested.
  • Who's Online   1 Member, 0 Anonymous, 2115 Guests (See full list)
