fibl619 Posted June 3, 2013 Report Share Posted June 3, 2013 [/url]" /> design for 2 fi bls 15 inch please help building tomorrow how does it look posting a pic and link if picture doesn't work goin inside a 4 dr blazer http://i1086.photobucket.com/albums/j458/elcajonlopez/pic.png Link to comment Share on other sites More sharing options...
mocrawlin Posted June 3, 2013 Report Share Posted June 3, 2013 double baffle the front for sure. Link to comment Share on other sites More sharing options...
fibl619 Posted June 3, 2013 Author Report Share Posted June 3, 2013 Ok im goin to double baffle were subs go and I want it to hit low and loud is this hairtrick capable currently only running an alpine mrp m2000 so 1000 watts rms right now till I get a fosgate t2500 or a crescendo 3500 this is my first box design I just want to know if it look good to build or did I mess up on something any help is appreciated Link to comment Share on other sites More sharing options...
ncc74656 Posted June 3, 2013 Report Share Posted June 3, 2013 im not sure what your going for, one of these the build your thinking of? nothing, gutted Link to comment Share on other sites More sharing options...
ncc74656 Posted June 3, 2013 Report Share Posted June 3, 2013 you should use dowel rods between the subs and port. will be about 8.19 cubic with the bracing nothing, gutted Link to comment Share on other sites More sharing options...
Joe X Posted June 3, 2013 Report Share Posted June 3, 2013 Here is a suggestion: Enclosure Specifications:Fb = 32.2 HzVb = 8.2 ft^3External Height = 21 inExternal Width = 35 inExternal Depth = 31 inPort Width = 28 inPort Height = 4 1/8 inCut Sheet List:* All Dimensions in Inches.* Wood Thickness is 3/4 for all Parts.External Enclosure Parts:2 x Top & Bottom (3 parts) = 35 x 31Left & Right Sides = 29 1/2 x 18 3/4Front & Back = 35 x 18 3/4L Port Internal Assembly Parts:Front to Back = 24 1/2 x 29 1/2Port Left Side Assembly:24 1/2 x 4 1/8Port Right Side Assembly:24 1/2 x 4 1/8 Assembly guide (generic dimensions): Important notes:- All boxes built outside the vehicle need to fit in their way in not just have the right dimensions.- This box should be operated around subwoofer(s) rated power. If that´s not the case, let me know.- The port needs 4 1/8" of free airspace in front of it for proper operation.- Setting your amp subsonic filter to 28Hz is suggested. Link to comment Share on other sites More sharing options...
fibl619 Posted June 3, 2013 Author Report Share Posted June 3, 2013 Here is a suggestion: Enclosure Specifications: Fb = 32.2 Hz Vb = 8.2 ft^3 External Height = 21 in External Width = 35 in External Depth = 31 in Port Width = 28 in Port Height = 4 1/8 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Top & Bottom (3 parts) = 35 x 31 Left & Right Sides = 29 1/2 x 18 3/4 Front & Back = 35 x 18 3/4 L Port Internal Assembly Parts: Front to Back = 24 1/2 x 29 1/2 Port Left Side Assembly: 24 1/2 x 4 1/8 Port Right Side Assembly: 24 1/2 x 4 1/8 Assembly guide (generic dimensions): Important notes: - All boxes built outside the vehicle need to fit in their way in not just have the right dimensions. - This box should be operated around subwoofer(s) rated power. If that´s not the case, let me know. - The port needs 4 1/8" of free airspace in front of it for proper operation. - Setting your amp subsonic filter to 28Hz is suggested. are those 1.5 dowels in the middle? Link to comment Share on other sites More sharing options...
Joe X Posted June 4, 2013 Report Share Posted June 4, 2013 Yes those can be done 1 1/2" no problem, what I wanted to make clear is that you need free 4 1/4" of space to the rear gate, if you don't then the above will need a small fix. Link to comment Share on other sites More sharing options...
fibl619 Posted June 4, 2013 Author Report Share Posted June 4, 2013 Yes those can be done 1 1/2" no problem, what I wanted to make clear is that you need free 4 1/4" of space to the rear gate, if you don't then the above will need a small fix. There will be around 4 1/2 of space between the rear gate so is it just (2) 1.5 dowels or is it 3 and what would be the height of the dowels? Also the measurements of the left and right port are 24 1/2x 4 1/8 but what about the middle is it the same ? sorry im a noob Link to comment Share on other sites More sharing options...
Joe X Posted June 4, 2013 Report Share Posted June 4, 2013 18 3/4" 2x4 lumber on the back panel, two 13 7/8" wooden dowel rods and for the port brace, that is the same height as the sides (4 1/8") but not as long as you can see on the sketch, and that is for aesthetical reasons so it doesn't look like two ports, just make sure the top down braces are right above that port brace. Link to comment Share on other sites More sharing options...
