masterbusa2 Posted June 8, 2013 Report Posted June 8, 2013 So I just got this car its a v6 auto, camaro. and last ngiht in the mcdonalds i put it in neutral, then after ordering i tried to put it in frive the selecter slid into drive fairly easy, but the car did not engage drive, i had to put in 1(low) then back up into Drive to get it to go into drive. anyone got any ideas also on my dip stick i cant tell is it suppose to be thick or more like slides off. I also noticed the fluid is brown, which normally means bburnt but it has never slipped or anything before always shifts fine, so i assume the dye just loses its color with age. planning tranny flush this friday but hte shifting thing is confusing me it can go into any gear fine except the D with the circle over it Overdrive.
boom50cal Posted June 8, 2013 Report Posted June 8, 2013 Do a full tranny flush/service and report back to us. Replace your filter and solenoids($50 together at most), and make sure your dipstick tube is properly seated also. On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole.
masterbusa2 Posted June 8, 2013 Author Report Posted June 8, 2013 okay so spent all morning and figured out with the gear selector the linkage had become lose and therfore none of the gears were in their correct spots now the brown tranny fluid i have read two things one never change it cause its caused by overheating, 2 change fluid and filter the fluid just looses color over time, now it doesnt smell burnt or anything, so maybe the fluid is just old? i have to wait till friday to get it changed too broke right now just gunna have to make it work xD
Miguels Posted June 8, 2013 Report Posted June 8, 2013 Do a full tranny flush/service and report back to us. Replace your filter and solenoids($50 together at most), and make sure your dipstick tube is properly seated also. oh no no no no. do not do a full flush. if the tranny has over 100,000 miles and did not get a regular oil maintenance you will more than likely damage it. seeing that the oil is dark i wouldnt do the a full flush. just take the pan out and replace what was in it and replace the filter edit: trans fluid not oil my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
masterbusa2 Posted June 8, 2013 Author Report Posted June 8, 2013 ya thats what i meant, Idk how to do a full flush as it is haha xD hopefully its jsut old fluid and all will be okay also while we are on the sbubject anyone know where a main leaking spot to power steering would be? i have to refil once a week like most common spot i guess?
Miguels Posted June 8, 2013 Report Posted June 8, 2013 the pan will have about 4 qt. the torque converter holds most of it. you can drain most fluid by disconnecting a line from your cooling lines and turn your car on till it starts to spit fluid. once it starts to spit turn car off so the pump wont suffer any damages. doing this i was able to replace 8 qt on my 4l60e which it should be the same tranny you have my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
masterbusa2 Posted June 8, 2013 Author Report Posted June 8, 2013 thats to do a full flush or to do what i need to do
Miguels Posted June 8, 2013 Report Posted June 8, 2013 thats not a full flush. that tranny has 12 qt in it. im trying to find a video on youtube for you my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
masterbusa2 Posted June 8, 2013 Author Report Posted June 8, 2013 Ight, like I said will have to wait until friday but i would like to see these coolant lines i need to undo to empty the torque converter
Miguels Posted June 8, 2013 Report Posted June 8, 2013 you dont have to do the tranny line. that only helps get more fluid out and also helps by not having fluid on the pan. if your pan has a drain plug then use that instead my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
