1999 Chevrolet Blazer - Stereo Integrity, Ground Zero, Soundstream
It would be circles cut out under the amps (5 under the 5k, 3 under the Levi), either pushing or pulling, haven't decided which yet. I think it would work well, since the meat of the heatsinks are on the bottom of the amp. If I were to mount amps normally, it's only the thin cover on the bottom, so I don't think that works well. But I think it would be better under these. Would be like my last one:
83E910C1-9875-4A44-81CB-C00DDC6DF63F-120
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
Dat wire
FA8E25B4-9437-437F-B78D-C3CA924F0077-135
KnuKonceptz Kolossus Fleks Kandy cable. 50ft of 1/0ga, 10ft of 4ga, and 16ft of 8ga, all OFC. 4ga for my Levi, 8ga from sub amp to box, 1/0 for everything else to include 2 positive runs front to rear. This is half of the wire I need, this is all my positive. Need an equal amount in black for negative. Will be getting Sky High Car Audio wire from Jim.
Also determined I need to make the amp rack myself, so I'll be picking up a few hand saws this weekend. May end up making my box too depending on how the amp rack goes. Anyone try the Craftsman bolt-on kit (http://www.craftsman.com/shc/s/p_10155_12602_00916496000P)? Gonna try it out, gonna get the drill, router, jigsaw, and sander attachments. Going to get a seperate 20V trim saw that will cut 45's as well.
So, faced facts that I need to build the amp rack myself, and went shopping today:
05A976E0-F3CC-4B7A-B44C-A766FCA841B3-158
73231BB8-C993-4E0E-A786-EC1E213D2626-158
Cordless trim saw, Craftsman bolt-on cordless kit with driver, router, and jigsaw attachments, Ryobi roundover router bit set and small drilling set.
Depending on how this amp rack goes, how accurate my cuts can be with only a circular saw, I may build my box as well instead of ordering one.
Got some work done on the amp rack/battery box:
B5380108-A809-4C0E-923A-F3B3FABFBD29-171
Both Lowe's and Home Depot didn't have full sheets of birch, which I find odd. They did have 2'x4' sheets of 3/4", which I used, and BARELY had enough with what I had leftover from the last box. Anyway, still need to measure and cut the two side pieces over the wheel well, because I changed the dimensions a little so the cardboard template won't work. Also need the $150 worth of fans I want to measure and do the cooling the way I want it.
Thinking about staining the whole thing. But it's such a pain in the ass. Might just leave it bare wood. Anyone got any ideas?
Shell is done.
8DCDA3FE-FD53-41FD-9BA9-2E72B7EBE19E-181
Not fond of this corner, but needed to be done to get over the wheel well
1495B741-1891-4D35-BE0E-9A6026725881-181
Need clean up some of the cuts and edges. Need to add some fans in there somehow, not quite sure how yet. Also need to add supports in the bottom, because the floor isn't exactly even.
Just got this in today:
69165F22-0C0E-4020-83FB-E68997B0688C-187
Combination ammeter/voltage meter and 500A 75mV shunt. Should allow me to see both voltage and current draw from my amps. Hopefully I can wire it up correctly and not fry it. Got the manufacturer (Chinese) to provide me a translated wiring diagram, so I should be alright. Has anyone used something like this before?
Cut the top piece. Here's how it should look:
3D3EC1F8-A6DD-46E7-A636-B6F9912AA797-197
The amps will be mounted about .5-.75" off the board. Gonna have to use threaded rod and washers/nuts for the 5k because the mounting tabs are so far off the board. Threaded rod and washers/nuts are so ugly though. Anyone have any ideas?
But I am going to be drilling holes for all wires, routing all edges, then staining it. Will be on hinges so the long edge close to the 5k opens upward.
Made some standoffs from some material I got at Lowe's. Amps are 1.25" from the board.
EA9307A6-D5FD-437B-97C8-22AE3B20AF2C-205
9124B852-FF24-4770-A819-48248E011DEF-205
6DAC832F-6E72-437C-B004-8BAE9F3F5FA2-205
So that's where I am as of 15Jun. Didn't start it here from the beginning, so a couple things may seem odd, but I will try to update it here as I go along now.
Got tint done all around today. Done by a 3M authorized installer so it's guaranteed for life (as long as I don't lose the card). Got 35% on the front two windows, and 20% on all windows behind the driver in addition to the factory tint, so around 10% in the back.
9E06D627-D51A-4461-AB84-0D9C8B256B2D-232
Been workin on the amp rack/batt box a little, but nothin worth posting yet.
  • Who's Online   1 Member, 0 Anonymous, 816 Guests (See full list)
