Chevy S-10 Build 4-15"s 4-2400watt Amps
in the ballpark i'd say. my 15's take up 16 cubes. tho i hear if you have more power on tap, it's better to do a smaller enclosure. but might see half a decibel gain. it'll vary. if you got the plans i guess just keep rollin with em ;)
Nope no plans yet, thats what im thinking about now. In the kicker manual they say 3-5 cu ft per sub. 3 x 15.5” port, 22” long for each sub. in the manual they say if it is a bigger enclosure then you can send more power to it?
another question is if i need 3x15.5" port for one, should i do 6x31" for 4 subs? i have no idea when it comes to vented enclosure cause i usualy do sealed... let me knows...
03 Trailblazer EXT LT
In Dash
Rear Flip Down
Polk Audio Font & Rear Stage
Hifonics Zeus 4 Chan Amp
Hifonics Brutus Mono Amp
12" Rockford Fosgate Power HX2
T-Line tuned to 45hz
18"BTL T-line @31Hz (9 weeks pregnant)
okay todays progress:
forgot to get propane for the heater so i used i tiny electric sunflower....
dint get anything done cause its 10 below and the sunflower did jack.....
I did get my tablesaw together though :) put that to good use soon
i get out of class at 3:00 tommorw and i will get propane and hopefully start making somethen that looks like a sub box.
In Dash
Rear Flip Down
I have a blazer, so same vehicle basically....
If i were you, i'd do subs on top, all countersunk with double layer of wood (baffle, or w/e u call it).... ports on back bottom, or percision ports if you want.... I would make the box form around the wheel humps and then make a cover piece to put on the back by the tail gate so it looks seamless (maybe throw in a LED kicker logo built in the cover peice). I would then put the amps in the front of the box (behind drivers seats or rear seats depending on if u use back seats or if box will be on top of them)... Maybe flush the amps up in the box...
AND hell yeah it's cold.... -50 windchill walking to class this morning.... I'm saving my 18" fi build for spring break in a few weeks so i can go home and use my heated garage...
1st place circuit city car/spl show (maplewood,MN) 2006
146.6 dB's with 2 12" L7 and 1606d brutus
I've done subs back port back, subs up port up, subs up port forward, and subs up port back and subs up port back is the loudest in my vehicle.
2000 Ford Explorer XLT
-20" RVM "Buck" Wheels
-2.5% Tint
-CompuStar Vizion Alarm
-(4) Infinity Kappa 680.7cs 5x7"
-1 XStatic BatCap Model 300
-2 18" DC LVL 4's
-Amps are undecided
yea i decided to go to coolage somewhere close to home so i can work on it. You live close to the St. Cloud area or out of state?
also i want to keep my back seat so everything will go behind it.
as much as i wanted to do some fiberglassing in this build i think i just might go with subs facing up and the port in the back with the amps mounted somewhere.......
In Dash
Rear Flip Down
I'd do subs up port back, easy and loud.
Do you go tthe subs yet? I got 2 15" CVXs sitting next to me that need a new home :)
pm sent :)
In Dash
Rear Flip Down
  • 1 month later...
i think i should update this.... my long build just got a lil longer.
Was out with a bunch of buddys out on a mudding trail and i was just had balls to the walls....
Well when ya got an engine with 265,000 miles on it you never know whats going to happen...
So i had her in four by, and was going to go threw this huge mud pit well i gave her hell had it in second gear so it had some power yet the tires would be free spinning, and i made it threw and it was some hella fun and would do it again. i pull off to the side and let the truck take a rest and then i hear it...
A knocking coming from the rear of the engine, im assuming its rod bearings so yea, im going to take it apart one of these days and fix her so this build is on holllllddddd......
lame
In Dash
Rear Flip Down
ew, thats not going to be fun. i have an s-10 blazer and i wanted to rebuild it at school and my teacher wouldn't let me cause there is too much shitand it would be too hard to work in cause of limited space. haha. but hey,, if u do it right, shouldn't be too hard. lol, good luck. and sorry to hear it.
Bills
KwB
Team DC Audio Midwest captain
