Tahoe 2013/2014/2015 RF, FI, XS, SQ, TM, etc...
On the off chance when you pulled all your panels off, do you know what the speaker size is for the ones on the D pillar all the way in the back? I am replacing all my stock speakers and nobody lists the size of that one?
I will take a look the soonest i can. If i remember correctly it was bigger than 1" for sure but it was small, like 3" or smaller. lemme check for sure.
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
I believe it's a 3 1/2" in those pillars but I've read a couple websites so far and one person said it's a 1.5" but he fit a 3.5" with minor modifications behind the panels The other site I looked at said 3.5 or 4" but he bought adapters to fit 6.5's there. http://www.tahoeyukonforum.com/forum/showthread.php?t=12183
Well here's a picture i found on the internet but mine is the same so I am saying it IS a 1.5" speaker (if you were to move the tape measure appropriately and figure in mounting piece. You could replace it with tweets or larger though. As posted above people have fit 3.5" with some cutting. Don't need to replace with a 1.5"
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
Hey guys should I ground my rear battery(s) to frame OR body? I have a frame to body ground under the vehicle and 2 batteries under hood grounded to both.
Also, if my port is facing the rear hatch, could i attach a piece of MDF board somehow to the vehicle (not the hatch) to help eliminate hatch rattles or do you think it would act too much like an extended port? Basically from the bottom of the rear window and down, flat piece of wood Anchored solid to the vehicle, not the hatch, to eliminate the hatch from rattling like a mofo. Thoughts? I don't want to change the frequencies of the box though
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
Are you planning on using speakers there yourself Karkov? If so then you could either put a pro audio tweeter there or either a set of 3.5's or 4" speakers and I'm sure you can get them loud. I think I wouldn't worry about it until everything was in to see what it sounds like but if you wanted some rear fill then you could go with one of these... http://www.sonicelectronix.com/item_43391_Rockford-Fosgate-PP8-T.html
