beau123 Posted July 19, 2013 Author Report Posted July 19, 2013 It lost 2 square inches of port area due to the reduction in height but that is very little to make a meaningful difference. i calculated it all to centimeters.(We can buy mdf only in 14 mm 18mm or 22mm i almost always choose for 18mm because it is much cheaper when i make a mistake and must do it again.) can anyone check if it is all okey. outer dimensions 41,91X83X54. port assembly parts 38,31X39,37 38,31X19,05 I have modified the post above for metric units, the dimensions have slightly changed as I have now used 18mm wood thickness which is the nearest to 3/4" and rounded to integer metric units which will make doing your cuts simpler. Any questions let me know. if you want to make the cuts simpler yes please i always make mistakes with cutting the right sizes
Joe X Posted July 19, 2013 Report Posted July 19, 2013 Did you notice the new cutsheet in centimeters listed after the one in English units?
beau123 Posted July 22, 2013 Author Report Posted July 22, 2013 Did you notice the new cutsheet in centimeters listed after the one in English units? no sorry i can't find it only the first cutsheet that was a little bit too wide
Joe X Posted July 22, 2013 Report Posted July 22, 2013 Did you notice the new cutsheet in centimeters listed after the one in English units? no sorry i can't find it only the first cutsheet that was a little bit too wide Ok so I changed it again, now is in metric units and a little narrower, any further changes let me know.
beau123 Posted July 24, 2013 Author Report Posted July 24, 2013 Did you notice the new cutsheet in centimeters listed after the one in English units? no sorry i can't find it only the first cutsheet that was a little bit too wide Ok so I changed it again, now is in metric units and a little narrower, any further changes let me know. thanks Joe this looks perfect. i think i am going to cut the sheets and build it on monday and saturday. i am going to post the pictures when busy and all done.
beau123 Posted July 28, 2013 Author Report Posted July 28, 2013 I found a problem the sub will not fit itcan be 1,5 cm higher does it make a big diffrence?
Joe X Posted July 28, 2013 Report Posted July 28, 2013 I found a problem the sub will not fit itcan be 1,5 cm higher does it make a big diffrence? The sub cutout is 13 3/4" for that sub and the box is 16" tall so it fits in the box, what do you mean? do you want a taller box?
beau123 Posted July 30, 2013 Author Report Posted July 30, 2013 I have to screw it in the top and bottomplate a friend of mine built it with a longef port and he blew his woofer. i am almost finished with mine only a couple screws and it is finished
beau123 Posted August 3, 2013 Author Report Posted August 3, 2013 I have it in and already without tuning and the amp gains al the way down it sounds awesome just like i wanted pictures are comping later when i have it finished painted or wrapped
