95neon_thumper82 Posted June 28, 2013 Report Share Posted June 28, 2013 I have two mtx tens in a sealed enclosure I just built. they are 400 watt rms.4 ohm a piece and I'm running at two ohms and a 800w rms @ 2 ohm amplifier. no iver heard you can slightly overpower subs in sealed enclosures to gwt more out of them. is this true or false if true by how much? I'm trying to decide whether to buy a separate amp for my high and mids or by a new mono block to power my sub and use this amp for my mids and highs. and I think this will be my deciding factor. thanks in advance. <img src=http://i1332.photobucket.com/albums/w610/beastly666bassboy/IMG_9611192581855_zps9b9b76be.jpg border=0 alt= height="75" width="800"> Growing old is necessary... growing up is an option! Have fun or you might as well fall into a 6 foot deep hole. Its much easier to be smart and act stupid then it is to be stupid and act smart! You're only limited by your imagination! Stop limiting yourself! Optima yellow top6 guage cableJVC KD S36 headunitPower acoustik 1600w 750w rms @2 ohmsTwo MTX thunder 7000 10"sSealed box @4.04 ft^3Mojo Mat in the trunk Coming soon:1/0 awg cablebig 3... in 6 gauge(till i can get the money for 0)planet audio Crossover.2- 3.5's for the front.2- 6.5's for the doors2- 6x9's for the rear3- MB Quartz amps to power it all.1- 6" aeroport...soon! <p>My Log! Link to comment Share on other sites More sharing options...
Bradprobert Posted June 28, 2013 Report Share Posted June 28, 2013 Is the amp you are currently running a two channel or a mono block? [sharedmedia=garage:vehicles:2223] 4th-order under rear seat build log: http://www.stevemeadedesigns.com/board/topic/165708-4th-order-under-rear-seat-chevy-extended-cab/#entry2410477 SD, thank for the input. I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . Link to comment Share on other sites More sharing options...
Ashunte23 Posted June 28, 2013 Report Share Posted June 28, 2013 Are those 7000's? Link to comment Share on other sites More sharing options...
95neon_thumper82 Posted June 28, 2013 Author Report Share Posted June 28, 2013 Is the amp you are currently running a two channel or a mono block? bradprobert its a four channel set to two channel and bridged. its a cheapy dual brand. I plan to get all my speakers then do across the board amp upgrades with either RF OR Alpine units. I got to upgrade wiring too... before I do the upgeade though and run full 0 to the back I have I think its 4 gauge ran right now. but I have 0awg going for my big three then to the back. I'm kinda building as the pay checks allow ya dig? <img src=http://i1332.photobucket.com/albums/w610/beastly666bassboy/IMG_9611192581855_zps9b9b76be.jpg border=0 alt= height="75" width="800"> Growing old is necessary... growing up is an option! Have fun or you might as well fall into a 6 foot deep hole. Its much easier to be smart and act stupid then it is to be stupid and act smart! You're only limited by your imagination! Stop limiting yourself! Optima yellow top6 guage cableJVC KD S36 headunitPower acoustik 1600w 750w rms @2 ohmsTwo MTX thunder 7000 10"sSealed box @4.04 ft^3Mojo Mat in the trunk Coming soon:1/0 awg cablebig 3... in 6 gauge(till i can get the money for 0)planet audio Crossover.2- 3.5's for the front.2- 6.5's for the doors2- 6x9's for the rear3- MB Quartz amps to power it all.1- 6" aeroport...soon! <p>My Log! Link to comment Share on other sites More sharing options...
95neon_thumper82 Posted June 28, 2013 Author Report Share Posted June 28, 2013 Are those 7000's? yes sir they are indeedy. I bought em used for 50 bucks in a retarded band pass lol. <img src=http://i1332.photobucket.com/albums/w610/beastly666bassboy/IMG_9611192581855_zps9b9b76be.jpg border=0 alt= height="75" width="800"> Growing old is necessary... growing up is an option! Have fun or you might as well fall into a 6 foot deep hole. Its much easier to be smart and act stupid then it is to be stupid and act smart! You're only limited by your imagination! Stop limiting yourself! Optima yellow top6 guage cableJVC KD S36 headunitPower acoustik 1600w 750w rms @2 ohmsTwo MTX thunder 7000 10"sSealed box @4.04 ft^3Mojo Mat in the trunk Coming soon:1/0 awg cablebig 3... in 6 gauge(till i can get the money for 0)planet audio Crossover.2- 3.5's for the front.2- 6.5's for the doors2- 6x9's for the rear3- MB Quartz amps to power it all.1- 6" aeroport...soon! <p>My Log! Link to comment Share on other sites More sharing options...
BoomZoom808 Posted June 28, 2013 Report Share Posted June 28, 2013 Yes, you can overpower subs in a sealed enclosure or a ported enclosure for that matter. You just need to make sure the signal feeding them is clean and you are not having major voltage drop. Also you need to be more careful when overpowering subs in a sealed enclosure because you will not be able to smell the coil burning. It would probably be louder firing to the rear unless you are planning on sealing them off. That dual Amp can do 800 rms at 2 ohm? If I can give a little 10" 4 ohm MTX terminator sub 500rms clean I am sure those 7000's will take more too. You also could get more output going to a ported enclosure. 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12 Link to comment Share on other sites More sharing options...
95neon_thumper82 Posted June 28, 2013 Author Report Share Posted June 28, 2013 Yes, you can overpower subs in a sealed enclosure or a ported enclosure for that matter. You just need to make sure the signal feeding them is clean and you are not having major voltage drop. Also you need to be more careful when overpowering subs in a sealed enclosure because you will not be able to smell the coil burning. It would probably be louder firing to the rear unless you are planning on sealing them off. That dual Amp can do 800 rms at 2 ohm? If I can give a little 10" 4 ohm MTX terminator sub 500rms clean I am sure those 7000's will take more too. You also could get more output going to a ported enclosure. yeah its the xpe 4700 I believe for the amp its a four channel bridgeable and its rated at that exactly. whether I'm getting that or not I'm not 100% sure but that's what she's rated to. for real? to the rear? hmm... might have to try that. she sounds pretty mighty right now as it is. louder would be awesome though for sure... as for the ported enclosure I thought about that. but I went with sealed due to SQ I listen to a wide range of music and figured it would do best with punk and rock and still drop low for some e40 and trick daddy my next closure will be ported though. I have plans already its just a matter of time as far as a clean signal.... um that may be a lil while off I still have the factory head unit and I'm running through a line converter. so no guarantees there I'm upgeading that soon also kenwood baby! <img src=http://i1332.photobucket.com/albums/w610/beastly666bassboy/IMG_9611192581855_zps9b9b76be.jpg border=0 alt= height="75" width="800"> Growing old is necessary... growing up is an option! Have fun or you might as well fall into a 6 foot deep hole. Its much easier to be smart and act stupid then it is to be stupid and act smart! You're only limited by your imagination! Stop limiting yourself! Optima yellow top6 guage cableJVC KD S36 headunitPower acoustik 1600w 750w rms @2 ohmsTwo MTX thunder 7000 10"sSealed box @4.04 ft^3Mojo Mat in the trunk Coming soon:1/0 awg cablebig 3... in 6 gauge(till i can get the money for 0)planet audio Crossover.2- 3.5's for the front.2- 6.5's for the doors2- 6x9's for the rear3- MB Quartz amps to power it all.1- 6" aeroport...soon! <p>My Log! Link to comment Share on other sites More sharing options...
BoomZoom808 Posted June 28, 2013 Report Share Posted June 28, 2013 You are giving those subs 300 rms maybe, no where near rated or 800 watts Right from the manual- Power Output (14.4VDC, 20Hz ~ 20kHz): 50 Watts RMS x 4 channels @ 4 ohms and ≤ 1% THD+N 75 Watts RMS x 4 channels @ 2 ohms and ≤ 1% THD+N 150 Watts RMS x 2 channel @ 4 ohms (bridged) and ≤ 1% THD+N 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12 Link to comment Share on other sites More sharing options...
95neon_thumper82 Posted June 28, 2013 Author Report Share Posted June 28, 2013 holy crap... I feel sorta jipped now. but not so bad.. now I know that that once I upgrade its gonna be even louder. I know that this particular amp is the top of the dual xpe line. 4 channel with a 2 channel switch that supposedly puts out 800w with the two channels bridged. like I said supposedly. it was 80 bucks plus tax brand new lol so I'm not gonna cry too much about it... ill just chuck it and by another better quality. when I started out I had this box that I bought for ten bucks at a yard sale... and wanted something to power it. here's a pic of my original box.... so I was like dude less than a hundred bucks for some bump? hell yeah... lol then I acquired these subs and it seemed to be perfect so that's the story but ywah a new amp is definitely in order lmno <img src=http://i1332.photobucket.com/albums/w610/beastly666bassboy/IMG_9611192581855_zps9b9b76be.jpg border=0 alt= height="75" width="800"> Growing old is necessary... growing up is an option! Have fun or you might as well fall into a 6 foot deep hole. Its much easier to be smart and act stupid then it is to be stupid and act smart! You're only limited by your imagination! Stop limiting yourself! Optima yellow top6 guage cableJVC KD S36 headunitPower acoustik 1600w 750w rms @2 ohmsTwo MTX thunder 7000 10"sSealed box @4.04 ft^3Mojo Mat in the trunk Coming soon:1/0 awg cablebig 3... in 6 gauge(till i can get the money for 0)planet audio Crossover.2- 3.5's for the front.2- 6.5's for the doors2- 6x9's for the rear3- MB Quartz amps to power it all.1- 6" aeroport...soon! <p>My Log! Link to comment Share on other sites More sharing options...
95neon_thumper82 Posted July 2, 2013 Author Report Share Posted July 2, 2013 You are giving those subs 300 rms maybe, no where near rated or 800 watts Right from the manual- Power Output (14.4VDC, 20Hz ~ 20kHz):50 Watts RMS x 4 channels @ 4 ohms and ≤ 1% THD+N 75 Watts RMS x 4 channels @ 2 ohms and ≤ 1% THD+N 150 Watts RMS x 2 channel @ 4 ohms (bridged) and ≤ 1% THD+N omg dude I'm sry I doubted you... this amp is weak as hell... I'm now looking for a new monoblock. lol this shit is bananas. B A N A N A S! lolz I've found a few I like on sonic. I'm gonna be ordering this shit asap. because this is stupid:D though for 300 watts she hits pretty good lolz <img src=http://i1332.photobucket.com/albums/w610/beastly666bassboy/IMG_9611192581855_zps9b9b76be.jpg border=0 alt= height="75" width="800"> Growing old is necessary... growing up is an option! Have fun or you might as well fall into a 6 foot deep hole. Its much easier to be smart and act stupid then it is to be stupid and act smart! You're only limited by your imagination! Stop limiting yourself! Optima yellow top6 guage cableJVC KD S36 headunitPower acoustik 1600w 750w rms @2 ohmsTwo MTX thunder 7000 10"sSealed box @4.04 ft^3Mojo Mat in the trunk Coming soon:1/0 awg cablebig 3... in 6 gauge(till i can get the money for 0)planet audio Crossover.2- 3.5's for the front.2- 6.5's for the doors2- 6x9's for the rear3- MB Quartz amps to power it all.1- 6" aeroport...soon! <p>My Log! Link to comment Share on other sites More sharing options...
