Gazoo_bumpin Posted February 21, 2008 Report Share Posted February 21, 2008 No one has said how this is used and what does it do and do I still need to use Body filler duraglass etc on top of this Moving where the Money Trees are Link to comment Share on other sites More sharing options...
LSN2meBoom916 Posted February 21, 2008 Report Share Posted February 21, 2008 No one has said how this is used and what does it do and do I still need to use Body filler duraglass etc on top of this Ummmmmm.......... They say RIGHT ON THEM what they do... 1st one is an "adhesion promoter"....and it says "prep" ....as in to prep the area so the fiberglass materials be it filler/resined glass etc will STICK...adhesion? adhere? to stick? Promoter=to make it more likely to happen...make sense? 2nd one says "plastic cleaner"....comon dude....really? 3rd one has lotta stuff- Far left="Flex filler"....filler...that will FLEX...without cracking.....then the next 2 are the same thing as in the 1st 2 pics.....then the "white tubes" with the pointy tops.....those are a mixable compound that will turn into the same kind of plastic used in the panels in ur car...like flexi-strong plastic that is made by combining the 2 parts-ever use J.B. weld? Body filler of any kind? Only diff with that stuff is it's more of a 50/50 mix I believe-I've never had the chance to use it but thats what it does. Some of that I guess is considered "Fiberglasser Mojo" but the part about NOT READING THE DAMN LABEL? common bro... COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly. Link to comment Share on other sites More sharing options...
Gazoo_bumpin Posted February 21, 2008 Author Report Share Posted February 21, 2008 Ummmmmm..........They say RIGHT ON THEM what they do... 1st one is an "adhesion promoter"....and it says "prep" ....as in to prep the area so the fiberglass materials be it filler/resined glass etc will STICK...adhesion? adhere? to stick? Promoter=to make it more likely to happen...make sense? 2nd one says "plastic cleaner"....comon dude....really? 3rd one has lotta stuff- Far left="Flex filler"....filler...that will FLEX...without cracking.....then the next 2 are the same thing as in the 1st 2 pics.....then the "white tubes" with the pointy tops.....those are a mixable compound that will turn into the same kind of plastic used in the panels in ur car...like flexi-strong plastic that is made by combining the 2 parts-ever use J.B. weld? Body filler of any kind? Only diff with that stuff is it's more of a 50/50 mix I believe-I've never had the chance to use it but thats what it does. Some of that I guess is considered "Fiberglasser Mojo" but the part about NOT READING THE DAMN LABEL? common bro... yes I did read the labels but just could’d understand how they all went together also if you see in the corner will post the pic that black and read tin can how did that go into the mix of things. So that 50-50 mix I just mix that up and then spread that all over the kicks and im done I was going to do the normal way fleece-resin-glass-bond etc and then spray a nice sem text coat but if I can miss a few steps I’m all for it on my kick panels. Moving where the Money Trees are Link to comment Share on other sites More sharing options...
LSN2meBoom916 Posted February 25, 2008 Report Share Posted February 25, 2008 Technically, you don't "need" any of that stuff man. try following this: http://www.stevemeadedesigns.com/board/ind...?showtopic=7394 or this http://www.stevemeadedesigns.com/board/ind...?showtopic=6132 or this http://www.stevemeadedesigns.com/board/ind...?showtopic=4254 or this http://www.stevemeadedesigns.com/board/ind...?showtopic=1579 on plastics http://www.stevemeadedesigns.com/board/ind...?showtopic=4186 COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly. Link to comment Share on other sites More sharing options...
Gazoo_bumpin Posted February 26, 2008 Author Report Share Posted February 26, 2008 Technically, you don't "need" any of that stuff man.try following this: http://www.stevemeadedesigns.com/board/ind...?showtopic=7394 or this http://www.stevemeadedesigns.com/board/ind...?showtopic=6132 or this http://www.stevemeadedesigns.com/board/ind...?showtopic=4254 or this http://www.stevemeadedesigns.com/board/ind...?showtopic=1579 on plastics http://www.stevemeadedesigns.com/board/ind...?showtopic=4186 Well thanks I will look in more detail on those topics, I was just wondering about those products that I posted as I've never seen them before and had wondered about them and how they were used. I think I will just do the regular Fiberglas way I have almost everything I need for my front stage expect my 8 sub's-10's haven't picked yet I have to go to the yard and get some Door panels and factory kicks as I want to use those instead of the factory ones. It will be a good build and I will have pictures just need to get everything together and try and find some ever coat products etc. Moving where the Money Trees are Link to comment Share on other sites More sharing options...
