An Attempt At Setting RF Amp X-Overs ... Opinions?
Sutliff
System in sig in current ...
I know it is essentially "personal preference", but maybe I can be pointed in the right direction so I can stop chasing my tail ... & getting back aches from getting in my trunk to play with amp settings ... Here is what is likely a simple dilemma:
The T400-2 runs my 6.5" components up front, passive x-overs ( http://us.infinitysy...-perfect61.html ). I have the selector on HighPass, but still needs to be set on something. ???
24dB-Octave Crossover
Sensitivity: 90dB
Frequency response: 75Hz – 23kHz, ±3dB
The T500-1bdCP runnin' the Fi's ( http://store.ficaraudio.com/ib312/ ) just keeps me befuddled. Some say 80-100Hz, others 100-120Hz. But when I set it there, I know I am missing so much other available frequencies for this type of IB setup, ... at least I think. Is 155Hz too high? I know these are subs, & they are made to go low, & boy they DO ... & to truly make up the separation, I would have to look into some sort of mid-bass addition ... maybe some 8's or 6.75's, or the like, on another amp to take up some of the fill between the subs, & these components.
PS: Yes, I have a DD-1, & have set the gains, ... I have even talked to 2 tech guys at Rockford about gains ... but each time I was a dunderhead, & forgot to talk to them about freq./x-over points. #Ugh.
Thank you, Folks.
Zeke
'14
2003 Chevy Monte Carlo SS
Vehicle Details & Mod List: http://www.stevemeadedesigns.com/board/garage/vehicle/1703-chevrolet-monte-carlo-ss/
Audio Build Log: http://www.stevemeadedesigns.com/board/topic/143276-2003-chevy-monte-carlo-ss-audio-build-ib-build
Pioneer FH-P8000BT
Infinity Kappa Perfect 6.1
Fi IB3 (Two 12", 2-ohm SVC)
RF T400-2 & T500-1bdCP
MechMan S Series 240A
XS Power D3400 & D975
Personally I'd set the HP filter on the T400 to the area of 60-80hz .... whatever sounds better to you...
as far as the IB's go..... Again you can set to 100hz and be done with it.... or go a little higher so it meet the components at around 80hz....
off topic - photos of IB setup pwease???
Sensitivity: 90dB
Thank you, Folks.
Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear)
beaker- I know this sounds like a lot of anime bullshit, but it is true.
Ask, & you shall receive ... (There are also more in my build log, & the whole build process ...):
Zeke
'14
Pioneer FH-P8000BT
They fire up through the OEM 6x9 holes & other OEM holes & notches. Not a single hole or anything was modded.
Zeke
'14
Pioneer FH-P8000BT
Bump ...
(seems to be a busier time ...)
Zeke
'14
Pioneer FH-P8000BT
  • Who's Online   0 Members, 0 Anonymous, 429 Guests (See full list)
